587,449 active members*
2,501 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Small tools on the pre-setter
Results 1 to 5 of 5
    Jun 2008
    62
    I'm planning on using a .03, and .02 carbide endmills on my table tool setter in my VF-2 and the feed rate seems awfully high for that small of a tool. Seems like it may chip at that initial feed rate at first touch. What do you guys do? and how small of a tool have you successfully touched off on the probe.? Thanks
    Aug 2006
    12
    I have chipped .125 end mills and have not .047 end mills. It really depends on how clean the tool setter is. I have ran some .015 end mills in a HAAS before but I did not use the tool setter. I personaly would use brass shim stock and do it manually.
    Mar 2008
    638
    I use the tool setter for 1/32" endmills frequently. At first I manually reduced the feed rate but then forgot to later. No chiped tools yet. So I don't bother to reduce the feed rate on those anymore (short and relatively stiff). I still reduce the feed for .05 and smaller drills however.
    Dec 2008
    717
    Using the toolsetter with the tool rotating slows the feed down also. You just put a rough height in, and it stops above, turns the spindle on reverse, and eases down onto the setter. Not sure if that speed would chip the tool.
    P9853 (I believe)
    Tim
    Sep 2006
    81
    I never recommend going below 1/32 on a contact tool setter...have I gone smaller successfully? Yes, would I trust it every day? No.
    For what it's worth, your HFO can retrofit a non-contact tool setter into your probing package on the machine...it's expensive, but I have a customer setting a 0.002" tool every day with it (the particular model they have will go as small as 0.001"), as well as lots of other customers using them for various other reasons...they're a LOT faster than the contact probes are too...VERY VERY fast for broken tool detection too, make a rapid move into the beam by the tolerance specified, if it see's any light, it's broken, if it sees no light, it's good and makes a rapid move out...it's amazing how fast it is.
  1. Tool Setter Macro for M-V60C and Metrol Setter
    By mitshack in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-02-2013, 12:08 PM
  2. Tool setter macro for M-V60C and Metrol setter
    By mitshack in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-06-2008, 02:38 PM
  3. depth of cut for small dia tools
    By plastibob in forum MetalWork Discussion
    Last Post: 08-05-2008, 08:05 PM
  4. Small multi-machine tools
    By thetrillionaire in forum Smithy
    Last Post: 12-24-2007, 09:44 PM
  5. sinks/small radius tools
    By bud in forum CNC Tooling
    Last Post: 01-04-2007, 02:43 AM
