587,775 active members*
2,974 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Small radius good Large radius bad
    Jul 2013
    12
    Hi everybody.
    I have a 3016 HT -97 with 32MP controller and I have run in to a little problem.
    I am trying to run 6082-T6 aluminium at 450mm/min with a 6mm 3-flute carbide aluminium end mill running at 7500 or 9500 rpm.
    When I make small circular ( 6.5 - 15mm ) interpolations the surface is very good you barely could see the tool marks, but when the diameters get bigger the surface finish get worse and almost look faceted.
    I have tried to speed up the feed and then lowering the feed, taking small finish cuts with depth of cut 0.2mm or large 1mm, I have even tried to do the operation with a larger tool 12mm and 50mm but it stays the same.
    The dimensions of the milled parts is very good and even , +- 0.01mm to +-0.02mm and the work-holding is very solid and rigid and there is no or very little vibration noises when running and the cutting fluid is plentiful.
    I am very thankful for all help.
    Best Regards.
    Fredrik
    Jan 2006
    2985
    Does your machine take G code? Is it using a bunch of straight (G1) moves or is it using G2 and G3 for the radii? It may be that the toolpath actually contains the facets and on small radii you cannot see it because each facet is so small.
    That's the first thing to check.
    Jul 2013
    12
    Hi.
    Thank's for the reply.
    The cam-program puts out a G2 or G3 depending on the direction so it should be correct.
    I have gone through some manuals today and there is a Gain setting in the SV menu ( M 90 ) I will try to see what the settings are for the standard and also see if I get any different and better result when using M91 if the default setting is way to high.
    Fredrik
  1. Replies: 1
    Last Post: 05-15-2013, 08:52 AM
  2. Large Radius does not look correct
    By hkenuam in forum BobCad-Cam
    Last Post: 03-23-2012, 06:26 PM
  3. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  4. Cutting Large Radius with Endmill Tilted
    By MotoDan in forum MetalWork Discussion
    Last Post: 10-22-2008, 05:38 PM
  5. large radius endmill
    By kentsui in forum Toolgrinding / Toolgrinding Machines
    Last Post: 07-09-2008, 12:30 PM
