587,686 active members*
3,178 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Slotting Titanium 3/16" Endmill
Results 1 to 7 of 7
    May 2006
    150
    Guys,
    What speeds and feeds do you recommend for cutting a 5mm slot, 5mm deep in Titanium? I have a 4 flute roughing cutter.
    I have turned one titanium part on a lathe, but I've never milled it.
    Thanks in advance.
    Rob in Ohio
    Oct 2007
    20
    is your endmill hss or carbide? any coating?
    May 2006
    150
    My endmills are HSS without a coating. They might be Cobalt, I'll check on that.
    Would a coating help for this application?
    Would it be OK to take several cuts to reach the final depth? I know that titanium will work harden easily.
    Thanks for your help.
    Rob in Ohio
    Apr 2007
    64
    There are four groups of Titanium and you didn't specify
    which one you are machining.
    There is unalloyed Titanium Example=Comercially PureTi-0.2Pd
    Titanium alloys (Alpha groups) Example=Ti-8Mn,Ti-5Al-2.5Sn
    Titanium alloys ( Alpha Beta groups ) Example=Ti-6Alv-4v,Ti-6Al-2Sn-
    Titanium alloys ( Beta groups ) Example=Ti-3Al,Ti-13V, and 11Cr-3Al
    The feeds and speeds are for the Beta groups the toughest
    to machine if you want them for another group specify
    which one you want.
    This is for 3/16 m42 uncoated roughing endmill 4 flute
    RPM=670
    Feedrate=0.8
    This is for 3/16 tin coated roughing endmill 4 flute
    RPM=1020
    Feedrate=1.2
    This is for 3/16 TiCN coated roughing endmill 4 flute
    RPM=1690
    Feedrate=2.0
    These feeds and speeds are for 1 diameter wide x
    1 diameter deep. ( 3/16 wide x 3/16 deep
    May 2006
    150
    gsrmmeza, thank you!
    The material is grade 2. I'm not sure of the exact alloy.
    I've been told that grade 2 is easier to machine. The material isn't that critical for this application.
    Thanks again!
    Rob in Ohio
    Apr 2007
    64
    For unalloyed titanium use the following:
    3/16 uncoated m42 roughing endmill 4 flute
    RPM=2040 Feedrate=2.4
    3/16 TiN coated roughing endmill 4 flute
    RPM=3060 Feedrate=3.7
    RPM=4690 Feerate=5.6
    For Alpha groups use the following:
    RPM=1690 Feedrate=2.0
    RPM=2380 Feedrate=2.9
    RPM=3730 Feerate=4.5
    For Alpha-Beta groups use the following:
    RPM=1020 Feedrate=1.2
    RPM=1570 Feedrate=1.9
    RPM=2710 Feerate=3.3
    I already gave you the Beta group feeds and
    speeds. Grades 1-4 are considered to be pure
    and unalloyed. You will need to do some cutting
    to figure what works to your liking. Remember to
    use new sharp cutters and plenty of coolant.
    May 2006
    150
    Gsrmmeza,
    Thanks again! :cheers:
    Rob in Ohio
  1. slotting programme
    By davedoubleu in forum Haas Mills
    Last Post: 09-27-2007, 08:42 PM
  2. Slotting MDF
    By Me2 in forum Material Machining Solutions
    Last Post: 07-28-2007, 05:25 AM
  3. Slotting for CNC
    By Kavanthony in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2007, 10:20 AM
  4. Slotting 1095
    By tr4252 in forum MetalWork Discussion
    Last Post: 09-28-2006, 12:59 PM
  5. Sqealing .75" 6 flute endmill
    By jderou in forum Uncategorised MetalWorking Machines
    Last Post: 03-13-2006, 02:48 PM
