I need to cut this piece.
http://bb.steelguitarforum.com/userp...crank_03_1.jpg
There's a slot going to the larger hole and a threaded hole that runs through the slot. My question is, what's the right order to cut the slot and drill/tap the screw hole?
Do I cut the slot and then drill and tap the small hole? Or do I drill and tap the small hole and then cut the slot?
