587,567 active members*
3,857 visitors online*
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    Oct 2010
    670
    Re: SlantPro Toolsetting
    Quote Originally Posted by keen View Post
    Thanks - Well that is one of the causes, but also tool and part flex, Z or X slideway settling under the cut load, spindle bearings/gravity/chuck variations, thermal changes and so on , have a variable effect from tool to tool and job to job. Because these are difficult to anticipate, I think it is easier just to set it approx., take a test cut, then tweak to size.
    Cheers Cliff
    But in a way.... it's the same when you run the mill. The difference is that you adjust with things like stock to leave, wear offsets and such.
    The Body Armor Dude - Andrew
  2. #22
    Oct 2010
    670
    Hi - Let me try and explain. I think I see what you mean. A NC lathe is different to set than a mill. Usually three stages:
    - Set up the tools mechanically
    - Set up the work and tool offsets in X and Z and the heights or Y if you want to call it that
    - Set the tools cutting to code commands
    I split it into three stages because it is easy to think there is only the first two - that's how it would be in a perfect world. But if you just do the first two stages on a low cost lathe with say a probe fixed in a collet or chuck , the parts will not be accurate. You will then need to measure and tweak the offsets to get eg accurate diameters.
    Eg with each tool the X offset is not just a WCS, it is effectively also a X tool offset, and this sets the diameter.
    So what I am saying is given this final stage is required anyway, then you might as well set the tools less accurately via a quick more basic setting tool, then tweak the parts to get the final accuracy.
    Hope that makes better sense. Cheers Cliff
    Hey Cliff,
    Would it be possible to apply a mathematical "variable" say one for aluminum and one for 304 stainless steel as an tool offset adjustment? Would require some testing to set up the recipes but I think it's doable. Example: Let's say I have a 1" diameter test rod mounted in the chuck. I come down in X+ and touch off on the rod stock. My offset to enter into the tool setting tab would be X +1.0". Now that does not take into account the tools bite or part/table/other flexes. So we do a test cut at 0.090" and it actually measures .095". We now have a .005" variable to apply to our original 1.0" offset. So in the future, for this material I would use my 1" test rod, come down and touch off on the rod and enter 1.005" into my tool offset tab. To be clear, I've not proofed out this theory so I may be way off base. But I use a similar method on the mill.
    The general idea is to get the tools rapidly setup to within say .001" to .002" and then dial them in with the wear offset tab. I have to do the same with my mills if I'm trying to hit a super tight tolerance.
    The nice thing with the lathe is that your X position for your work is always in the same spot (or at least it should be). Once your tools are shimmed, your Y position is set and does not apply to your work piece. That leaves the Z position to set for your work piece.
  3. #23
    Feb 2007
    1538
    Hi Awall - I love your enthusiasm!
    But if you use a precision probing and that mathmatical variable, and still need to tweak the last thou or two via the wear offsets anyway, then why not set it approximately, get it to within 0.001" to 0.004" and then tweak it via wear or tool touch offsets?
    Also for machining a wide variety of parts, especially if you are doing ID work, I find about 20 - 30 tools/projection lengths are needed and the Turret 8 and gang 2 just cant supply that, so time consuming setting is still required each time for several special tools from scratch. This might not apply if you are making similiar parts in 'family' shapes and materials that suit the 10 available tools.
    Cheers Cliff
  4. #24
    Oct 2010
    670
    Cheers Cliff
    Some good food for thought. See, the real issue is that you've spoiled all of us with the ITTP and we just want the same convince on our lathes!
    Later,
    Awall
Page 2 of 2 12
  1. 6mb toolsetting
    By dandscuda in forum Fanuc
    Last Post: 06-13-2012, 05:36 AM
  2. Toolsetting macro on 0m-C
    By John_B in forum Fanuc
    Last Post: 01-02-2012, 09:03 PM
  3. new inexpensive automatic toolsetting device product
    By henry_phd in forum Uncategorised MetalWorking Machines
    Last Post: 07-14-2008, 05:34 AM
  4. need help with toolsetting macro
    By parksteel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-06-2008, 03:15 PM
