587,259 active members*
2,961 visitors online*
Results 1 to 4 of 4
    Aug 2007
    12
    SL-30 programing ?
    can you run the tall stock in 2 different positions in the same program?
    ive never ran a programmable tall stock before
    also im pretty sure M25 is advance what would be the M code for the retract ?
    :withstupi
    Dec 2007
    33
    M21 is advance, M 22 is retract. Parameters can be set/changed as needed.
    What ever your stop point is, set it 1" beyond, to maintain proper pressure onn the part.
    Mar 2006
    10
    You can command the tailstock to move to a certain point, ex. B-13.432, in MDI or in a program. I've never tried running a program like that though. I have always used M21/M22 so I'm not sure what the outcome would be.
    Aug 2007
    12
    well i just want to do it for show we had to kick and scream to get a new lathe so i though id write a program just to make it look cool im sure ill loose concentricity but hay who cares if it works as long as it looks COOL rite
  1. ? on programing
    By markjb in forum Fadal
    Last Post: 03-16-2009, 11:09 AM
  2. programing help
    By DARKWINZ in forum Okuma
    Last Post: 06-03-2008, 03:23 AM
  3. 0-M programing help please
    By venomgrrrl in forum Fanuc
    Last Post: 12-08-2007, 06:51 AM
  4. CNC programing
    By Fryzss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2007, 04:33 PM
  5. CAM programing
    By kenlambert in forum G-Code Programing
    Last Post: 02-03-2006, 07:03 AM
