587,083 active members*
2,816 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > SL-25B Mori Seiki Lathe Spindle Problem
Results 1 to 7 of 7
    Sep 2011
    0
    We have a problem with the spindle locking pin that will not move, it is in a retracted position. The spindle quill moves IN and OUT fine but the locking pin does not extend to lock the spindle for movement. We do not have the electrical schematics or manuals.. any help would be appreciated. Thanks!
    Feb 2009
    6028
    Are you talking about the tailstock and tailstock quill? Spindles don't move in and out on a SL.
    Sep 2011
    0
    Mori Seiki Lathe Spindle Trouble
    I am trouble-shooting this machine for the first time. Yes the quill moves in and out fine in manual and using M codes... but i think the spindle lock pin which is hydraulically controlled on this machine needs to extend so it engages with the tool change turret assembly, then when that axis moves it drags along the spindle base at the same time... our trouble is the pin is not extending outwards.. not sure if an Mcode is required or the mechanism is jammed..we have limited info.. i am an electronics engineering technician so I approach problems from that point of view... I noticed some you-tube video's and a different version of this same machine has a manual pin that i see the operator engages by hand for this movement to happen.
    Feb 2009
    6028
    You have the auto-tow along option on that tailstock. The Z axis has to be in the proper position for the pin to engage, there is a Mcode ( i dont have a ladder here to look it up) to position the Z axis to the last known drop off position. There also should be a manual menu under "custom" on the later machines, under "aux" on the 0-T controls. Don't try to push the tailstock around, unless you get the pin to extend, the base is hydraulically clamped on that model.
    Sep 2011
    0
    Thanks very much for the info. I will let you know how we make out with it.
    Have a great weekend!
    Aug 2011
    2517
    The automatic tailstock pick-up is G479 on Mori's
    like this.... (workshift reference setting tool = T2)
    (AUTO REMOVE TAILSTOCK)
    G28 U0
    M26 (QUILL BACK)
    G0 T0202
    G479 (GO TO TAILSTOCK PICK-UP POSITION)
    M78 (UNCLAMP)
    G28 W0 (ZERO RETURN Z)
    M79 (CLAMP)
    G00 Z200.0
    T0200
    M1
    (AUTO ADVANCE TAILSTOCK)
    G28 U0
    G0 T0202
    G479
    M78 (UNCLAMP)
    G00 Z50.0 (YOU NEED TO SET THE Z HERE YOURSELF SOMEWHERE NEAR THE PART USUALLY BETWEEN Z20.0 AND Z100.0 WORKS. REMEMBER THE Z POSITION IS IN RELATION TO THE TOOL POSITION NOT THE TAILSTOCK POSITION)
    M79 (CLAMP)
    T0200
    M25 (QUILL FORWARD)
    M1
    Sep 2011
    0
    That's great info Fordave11. Thanks for your help. We really appreciate it!
    I will give an update on how we make out with it... most likely on Monday.
  1. mori seiki FL-2 problem
    By cnyttbircan in forum Mori Seiki lathes
    Last Post: 10-21-2013, 09:58 PM
  2. Mori DL-20 dual spindle lathe problem.
    By Hargrave545 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-01-2011, 09:01 PM
  3. Mori Seiki Lathe Sl 3A
    By rajuicnc in forum Mori Seiki lathes
    Last Post: 09-27-2010, 12:37 PM
  4. problem in MORI SEIKI SL-0
    By metoaly in forum DNC Problems and Solutions
    Last Post: 10-07-2009, 07:03 PM
  5. mori seiki mill with a spindle problem
    By imwllc in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2005, 12:31 AM
