586,070 active members*
3,684 visitors online*
    Jan 2014
    10
    Sinumerik 828D Network Setup (Siemens)
    Hello Im working on 2 Leadwell's and im trying to get them on a network
    We have a Leadwell v40L Sinumerik 828D and a Leadwell v40 Sinumerik 828D Basic M
    I'm trying to find out where/how to edit network settings or does the OS connect via DHCP
    Do thy have FTP/SMB/VNC or some other way to transmit data
    We are Currently using USB for Program Transmission but we wan to have network communications like our Fanuc's
    If someone Can Give Me a link to a how-to or a Manual This Would be Appreciated
    I have Been looking and i cannot find anything in the manuals i have or on Google
    Thank You
    Hello,
    You can use RCS commander software to connect both CNC to transfering part program if you don't have "Network Management" Option.
    If you have this option then you can set an network share to you PC share folder under "Program Manager" screen. In order to make it works you need to setup.You can find related information under this Siemens DocOnWeb site:
    https://www.automation.siemens.com/d...13_e&scope=all
    and how to setup network drive is decribe in this chapter.
    I hope it helps
    Alan
    Feb 2011
    252
    hi,
    I have to SolidCAM.
    [email protected]
  1. Sinumerik 828D postprocessor Mill Solidcam
    By solidcamx in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 09-26-2021, 06:21 PM
  2. Siemens 828d continuous path mode problem
    By Michaelt83 in forum Mastercam
    Last Post: 01-05-2015, 08:56 AM
  3. g-code for sinumerik 828d problem
    By xray34 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-28-2014, 01:23 AM
  4. Replies: 0
    Last Post: 08-30-2013, 07:21 AM
  5. g-code for sinumerik 828d problem
    By xray34 in forum G-Code Programing
    Last Post: 09-17-2012, 09:51 PM
