587,420 active members*
3,184 visitors online*
IndustryArena Forum > CAM Software > Esprit > Simulation question
Results 1 to 4 of 4
    Jul 2008
    19
    Simulation question
    Does Esprit 2009 have the capability of capturing or "freezing" the graphics after simulating an operation? Displaying the solid block created in simulation parameters with the stock removed by previous program operations. On a complex part I have trouble visualizing the in work progress without running the simulation repeatedly. This is a crazy thought but I had to ask.
    2932
    I believe that capability was new in Esprit 2010. It's called Stock Automation, and it works very well.
    You should be able to simulate each operation or each tool by setting the Multi Step Mode to Tool Change or Operation in the Simulation Parameters Step Control. Then use the Multiple Steps button rather than the Run button.
    Jul 2008
    19
    Thanks, it does work with 2009 also. Not exactly what I was asking but like this way of running simulation.
    Mar 2012
    27
    Yes. After you simulate the operations go to the advanced simulation toolbar. Then select save as simulated state. Nothing to it. You can also highlight only the operations you want to run. Press play but don't press stop. Then you can save as simulated state. I've been programming with Esprit since the Esprit X days before all the pretty cartoons.
  1. X5 Simulation
    By Rathi in forum Mastercam
    Last Post: 09-20-2011, 01:38 AM
  2. CAM Simulation OK but........
    By masterfabr in forum Fadal
    Last Post: 02-16-2010, 09:06 PM
  3. Simulation question winch and line ?
    By Craigpat in forum Solidworks
    Last Post: 10-17-2009, 05:16 PM
  4. NC Simulation
    By 5axes in forum Visual Basic
    Last Post: 07-06-2009, 08:57 AM
  5. Simulation only ?
    By patrickb in forum FeatureCAM CAD/CAM
    Last Post: 05-27-2006, 02:01 PM
