587,629 active members*
3,444 visitors online*
IndustryArena Forum > CAD Software > Solidworks > simulating a cable between moving parts in solidworks assembly
Results 1 to 2 of 2
    Jul 2005
    450
    I have a solidworks assembly with a moving stage and am trying to model a cable between the moving and fixed parts. I have tried creating a part with sketches constrained to both moving and fixed sections, however when dragging the moving part in solidworks, the sketch doesn't update until I manually hit rebuild.
    Is there a better approach for doing this? one that will make the cable path update in real-time?
    Dec 2009
    14
    Use a chain/belt relationship.
  1. Importing a solidworks assembly
    By JonathanC in forum Rhino 3D
    Last Post: 10-18-2011, 01:38 PM
  2. SolidWorks assembly to Gibbs Cam 4 axis
    By GriffinFab in forum GibbsCAM
    Last Post: 03-17-2011, 10:01 PM
  3. Moving to NX7 from Solidworks & Mastercam
    By Aquatic in forum UG NX
    Last Post: 12-16-2010, 10:45 PM
  4. Haas Cable Assembly Connectors
    By Mr. Technical in forum Haas Mills
    Last Post: 06-03-2010, 09:14 PM
  5. Replies: 4
    Last Post: 12-15-2009, 12:13 AM
