Hi. I have a Flashcut 8300 Mill that I've been operating with Sheetcam for two months. My next effort will have me cutting "sloped slots" parallel with the X axis but pitched relative to the Y axis. I will modify the router mount such that the router shaft will be approximately 15* from the verical Z axis, the same 15* pitch of the required slots. What I need is a CAD product that will provide for repositioning the gantry a few thousandths along the Y axis prior to the descent of the Z movement and the subsequent pass made along the X axis.
The (straight) cutter is .093 diameter that climb-cuts a .123 wide slot in each roundtrip pass, descending .040 at a time, in aluminum. Sheetcam and my puny brain worked well with vertical slots, but I need another CAM product it appears to handle my slanted slots.
Assuming I have illustrated my effort, might anyone have any suggestions for a simple solution? Happy to clarify...Thanks in advance, BJ
Seems I'm confused (again). The solution can be found by creating a new set-up file in Flashcut, such that a change in Z will modify Y like a gear-ratio. I'll have to talk with a real machinist next for the trig involved; it's 1 over the sine (or is it the cosine?..hah!) Anyone experianced with this who might have advice? Thanks, BJ
