587,779 active members*
2,824 visitors online*
Results 1 to 2 of 2
    Jul 2008
    2
    SIEMENS 840D PROGRAMMING QUESTION
    Hey, can someone help me with one small query.
    I work with a Milling/Faceting machine which works on Siemens 840D.
    I want to know how to program an interpolation on one out of two already synchronized, running axes.
    For example: I synchronize rotary B-Axis with the Spindle (its making 50 cuts per rotation[TRAILON]) .
    While this is on I want to make an interpolation: G01 Y-5 B50 F250
    This does not work. How can i make these sequence of events work?
    I would really appreciate your help.
    Mar 2015
    1
    B axis may not be flexible axis, it's may be fixed axis , primary axis can move after locked secondary axis
    means b axe locking unlock system, check oem manual
  1. DMU70 Siemens 840D Probe programming
    By RdHawg in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-13-2014, 03:19 AM
  2. Siemens 840D Programming
    By M.RISHIKESH in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 11-14-2013, 10:29 AM
  3. Need Siemens 840D Help
    By gears2010 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 07-25-2013, 03:54 PM
  4. DMU70 Siemens 840D 5ax feedrate question
    Last Post: 01-07-2013, 11:51 PM
  5. VB & Siemens 840D
    By Thunder in forum Visual Basic
    Last Post: 09-22-2007, 04:28 PM
