587,493 active members*
3,337 visitors online*
Results 1 to 2 of 2
    Jul 2008
    20
    Siemens 810M 1682 error code
    Anyone have experience with this error code?
    Manual says:
    "Servo enable travel axis"
    The axis-specific servo enable signal was removed by the PLC user program during traversing"
    "Inhibiting of NC START"
    What does this mean? What do i look for?
    I think the "2" in 1682 is the axis which in this case i think would be my Z axis. 0=X, 1=Y, 2=Z, 3=W but this is a guess.
    My router crashed twice on the same Z move with this error while cutting wood but would not repeat the error dry running.
    Stuck with holes in my spoil boards....
    1993 Motion Master CNC router. Siemens 810M Dual head.
    Thank you.
    Jul 2008
    20
    Did some testing last night and could not replicate the error. Dry ran twice and then ran with the routers 1/2" above surface and then at surface. (Installed a Z safety block so the heads would not drop if it crashed again) Ran that test at reduced speed and full speed. No issues.
    Did not get to cut wood yet. Will try that this weekend.
    I'm Begining to think the controller was just having a bad day. My dad jokes that i had some bad elctricity.... He has had off days with the controllers in the past.
    Going to replace the battery.
    Will report again.
  1. SINUMERIK 810M - 7024 error
    By rliovic in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 09-23-2011, 04:20 PM
  2. Siemens 810M Communication. help Needed
    By mjhjenks in forum DNC Problems and Solutions
    Last Post: 07-04-2010, 05:42 AM
  3. Siemens 810M 1720 ORD + X error (Motion Master Router)
    By mjhjenks in forum Controller & Computer Solutions
    Last Post: 03-02-2010, 11:06 PM
  4. Subroutine for helical interpolation on Siemens 810M
    By Canister in forum G-Code Programing
    Last Post: 10-05-2009, 11:23 AM
  5. Siemens 810M initialization
    Last Post: 02-16-2009, 04:16 PM
