587,875 active members*
3,525 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > ShuttleXpress - Tormach version required?
Results 1 to 7 of 7
    May 2011
    100
    Does anyone know if the Tormach Shuttle is an OEM version, or does the off-the-shelf ShuttleXpress version work for Mach? I've got a Tormach version on my 1100, but I'd like to add one for a CNC router I have too. What is required to make a non-Tormach version work?
    Apr 2008
    61
    I use the Expess and Pro version with Mach. I just love them.
    Feb 2006
    1072
    I'm not quite sure if this is answering what you're asking, but I bought a second shuttle from Tormach and am using it (and its plugin) on a stock copy of Mach3 that I use with my lathe. As far as I know all that is custom on the Tormach version of the shuttle is the silkscreening.
    Randy
    May 2011
    100
    Quote Originally Posted by zephyr9900 View Post
    Randy
    Thanks for your answer. I'm actually trying to figure out if the reverse is also true, that is, can a standard generic ShuttleXpress work with Mach as is, or is anything special about the Tormach version other than the labeling and 'badge engineering'? I'll continue to use my Tormach version on my Tormach, but I'd like to get a 'standard' unlabeled one for use on my Techn-Isel CNC router. It's also about half the cost.
    Feb 2006
    1072
    I think that the Xpress plugin is not customized for Tormach. John Prentice modified the plugin from the Shuttle Pro plugin if I remember correctly, and also if I remember correctly had two Xpress'es attached to his own lathe.
    Randy
    Sep 2009
    318
    I bought one for my lathe and got the plugin working but the jog is very slow compared to the Tormach. I have not delved into it yet but I am sure it is just a setting that needs to be changed.
    Feb 2006
    1072
    I found the video of John Prentice with two Xpress'es on his Mach3-controlled Boxford lathe. It's http://www.castlewoodconsultants.com...ningTCL240.wmv
    Randy
  1. powermax 45 machine version vs hand version
    By landmark in forum Hypertherm Plasma
    Last Post: 02-14-2010, 11:13 PM
  2. how to tranfer old version post to new version
    By ming035 in forum GibbsCAM
    Last Post: 02-11-2010, 08:08 PM
  3. New Version Release: Tormach PCNC 1100 Manual
    By ag53711 in forum Tormach Personal CNC Mill
    Last Post: 09-24-2009, 05:17 PM
  4. Newest version of Mach3 Version 1.90.065
    By turmite in forum Mach Mill
    Last Post: 01-27-2009, 04:21 AM
  5. Replies: 2
    Last Post: 12-12-2006, 12:12 AM
