587,221 active members*
2,938 visitors online*
Results 1 to 6 of 6
    Sep 2008
    6
    Shuttle Pro Problem
    Hello had the shuttle pro for awhile now and still cant get it to jog properly...I get the same error..
    Thu - 21:17:01 ---Unknown word where unary operation could be
    Thu - 21:17:02 ---Unknown word where unary operation could be
    I have reinstalled everything three times....but the same stuff...also confirmed I am on USb 2.0 in case that was an issue.....the funny thing in the two types of config....it works...I just keep getting the error above when its time to use it in mach3....does anybody have any feedback.
    thanks
    cnc guy toronto
    35538
    Did you install the shuttle software? If you did, uninstall it.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2008
    6
    I did
    This hase been happening to me for some time....prior to last night I was just running the mach3 plugin on its own and the same thing happened....
    anythoughts !!!
    Dec 2007
    341
    hello i was having diffuculty also and could not get it figured out i had a melt down one day .And had to reinstall mach i got rid of the lockdown version and went to the next version of mach i had saved my xml previously to anouther computer and when i got rid of everything including mach and all files and uninstalled shuttle pro not just redownloading it over the previous install and when i installed mach and then shuttle pro and reloaded the xml it started working like it should .And has been fine ever since i got those same messages you got .If this does not work go to yahoo goups and join go to the mach two group and ask art he desined mach and wrote the plugin for shuttle pro if he can not help you no one can.It sure is worth a try
    35538
    Yes, you really need to use the latest version of mach3 and the newest Shuttle plugin.
    Gerry
    May 2008
    11
    Chips in ShuttlePro
    I have been having problems apparently from chips in the ShuttlePro. Does any one have a clever way of sealing it to keep out chips?
  1. Turret shuttle fault
    By jprobst in forum Haas Mills
    Last Post: 09-23-2009, 04:05 PM
  2. Shuttle In Problem
    By CountBraden in forum Haas Mills
    Last Post: 08-24-2008, 05:57 AM
  3. Could someone help me setup my shuttle express in EMC?
    By fusion_crank in forum LinuxCNC (formerly EMC2)
    Last Post: 06-17-2008, 06:19 PM
  4. VF3 SHUTTLE IN FAULT
    By JACKOFTRADES in forum Haas Mills
    Last Post: 11-29-2007, 05:23 PM
  5. Jog Pendant or Shuttle Controller?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 09-04-2007, 03:47 PM
