I am in the middle of a job that on the surface really don't look like much to build. It is a stand from a private owned water plant.
The problem is I had none of the old stand to work with Literally fell apart from rust.
There is a pump & a motor that are coupled with a lovejoy type motor coupler. The shaft height of the motor is different from the pump
This is a 1 off job that will have a total cost of somewhere around $500.00-$800.00 because it will take several hours to calculate the differences in shaft mounting height, there will be 7 different pieces that will have to drawn in CAD But only about 2 hours total of cutting, assembly & welding.
Point being You have to charge for CAD or engineering time on 1 off parts.
If it works.....Don't fix it!
