586,974 active members*
3,121 visitors online*
Results 1 to 3 of 3
    Jul 2003
    276
    Gingery style rails??
    How well do you think a rail based on the Dave Gingery Lathe design would work?
    I ws thinking 2" wide CRS mounted to a 1" steel tube or u channel of some sort with a bearing like this (copied from Dave's Lathe manual).
    The upper part could be cast any size needed, the lower section has a piece of key stock riding against the side of the flat crs rail using the set screws to remove any play. Maybe using UHMW on the bottom of the bearing (on top of the CRS) would allow it to freely slide.
    I guess I need to see what is inside a regular linear bearing. Are there ball bearings? or what?
    May 2003
    323
    Sir,
    What will you be using this rail for? Is it a lathe or mill? How fast does the carriage move? I have used cold drawn flat with ball bearings for my router.
    Regards,
    Jack C.
    Jul 2003
    276
    for a router
  1. Working with structural extrusion
    By uscra112 in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 07-24-2007, 04:36 AM
  2. Add a second set of rails to X axis..need advice.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 06-01-2005, 01:11 AM
  3. Y-axis rails
    By 2muchstuff in forum Mechanical Calculations/Engineering Design
    Last Post: 04-15-2005, 04:01 AM
  4. Shafts or rails?
    By sjmarsha in forum DIY CNC Router Table Machines
    Last Post: 06-30-2004, 12:49 PM
  5. Anybody seen or used these rails
    By xairflyer in forum DIY CNC Router Table Machines
    Last Post: 01-20-2004, 10:20 AM
