Came accrss these, low profile rails and carriages.
Cost is very good I worked out that two 27mm (1 1/8") wide rails and two carriages on each 300mm long (for z axis) would cost £67.50stg from RS components who are not known to be cheap for anything over here.
Waiting on reply direct from IGUS.
The rails are available up to 3100mm (10ft ish).
They do a rail/carriage that is 80mm (3 1/4") wide, I wonder if you could use this a z axis on its own.?
http://www.igus.co.uk/Main_fs.asp?KA...O=START_DRYLIN
