586,909 active members*
3,440 visitors online*
Results 1 to 15 of 15
    Apr 2007
    5
    VFD Help needed
    Hey guys need some info to get me started. Kl-vfd15 I can't seem to get it working. I have power, and have a Flashing display of A5R 1.0 5 could be a "S" but not sure. Only button that work's from here is the prog button, which then give's me flashing PD000, press prog again then i can use the arrow up and down buttons to change PD value. I can use the button >> to change digit postion and then arrow up down buttons, and that's it.
    Is their a combination of buttons together to push? don't know what the Jog button is for either. In info to enlighten me would be great.
    Ray
    24223
    You don't have a manual?
    What is the make of the VFD?
    Al.
    Apr 2007
    5
    Afraid not didn't come with a manual, although i was sent a pdf file, after i sent a message to keling support, but that's not helping me, it talks about pressing Enter, will this unit doesn't have Enter. So i guess the pdf file is genric.
    For the make of the VFD have no idea, it only has KL1500 stamp on the front.
    Ray
    Feb 2007
    4553
    Post
    Ray,
    Does this look like your VFD?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2007
    5
    No it doesn't look like that. Where you have F/R button, mine is a Jog Button. Where you have a Enter Button, mine is a Set Button.
    Also only my Power light come's on, the other's haven't come on at all as yet.
    Ray
    Apr 2007
    5
    Ive borrowed this from the woodwork forums. It's the best that i can find. At least it looks the same as mine, from what i can see.
    Feb 2007
    4553
    Post
    Ray,
    I believe this is the model you have.
    Feb 2007
    4553
    Post
    Ray,
    Here is the setup documentation.
    Jeff...
    Attached Files Attached Files
    Apr 2007
    5
    Jalessi, thank you for VFD file it will be alot of help further down the track. But I really don't understand why, I can't progress any further than i have. Except for pressing the "Set" button and the Arrows up & down buttons i can't enter any other information into VFD. Pressing the other buttons don't have any effect on the unit. I had assume at factory settings the spindle should work, but it doesn't, I simply can't get passed a flashing digital readout. Am i missing something here??
    Ray
    24223
    If you bought this new, I am surprised if you did not get a manuf. manual?
    All the VFD's I have worked on, a flashing display usually means there is an error of some kind or that something illegal operation is being performed?
    Al.
    Apr 2014
    Re: VFD Help needed
    jalessi,
    I am looking for a manual on how to set up my KL-VFD15 as well. The Zip file you posted, is that for the HY02D223B model VFD? or is that for a KL1500VFD?
    Feb 2007
    4553
    Post Re: VFD Help needed
    Quote Originally Posted by dcolo View Post
    jalessi,
    Dcolo,
    See attached PDF for KL1500VFD manual.
    Jeff...
    15362
    Re: VFD Help needed
    raysul
    How have you wired the input terminals, can you do a photo
    Mactec54
    Apr 2014
    Re: VFD Help needed
    thank you so much! We are in the process of setting our table up now.
    15362
    Re: VFD Help needed
    dcolo
    What is the spindle Hz 400 or Hz 300 & the spindle motor Amps, Post these to numbers, & I will post all the settings you need
    Mactec54
  1. Help With Project Needed - Guru Needed Please
    By cuetipper in forum DIY CNC Router Table Machines
    Last Post: 12-03-2012, 10:58 PM
  2. CNC'ing Needed
    By pbp in forum Want To Buy...Need help!
    Last Post: 06-28-2012, 06:35 AM
  3. RFQ needed...parts needed ASAP
    By billet works in forum RFQ (Request for Quote)
    Last Post: 10-12-2011, 01:39 PM
  4. Space needed behind TM-1 needed?
    By helocat in forum Haas Mills
    Last Post: 05-20-2010, 02:31 PM
  5. cnc guy needed $$$
    By greatscott in forum Community Club House
    Last Post: 02-26-2007, 05:43 AM
