586,664 active members*
5,492 visitors online*
    Dec 2009
    hacking a roll to roll tape printer
    Hi fellow hackers,
    I'm trying to put together or find a machine that can:
    - be fed by a sheet of 3M restickable tape
    -- hacked together as a series of consumer 1/2" rolls adjacent to one another
    - print continuously on this tape
    -- just lines, nothing fancy
    - has a post-print roll collector such that at the end of the process the roll is "rolled up" again (just like how it started)
    Can any of you more experienced with these kinds of machines help suggest anything close to turnkey?
    I could go as simple as a Brother continuous label printer, but there's no way to easily get the tape/paper back into a roll.
    I *think* I should hack together a solution with a plotter that has a roller-receiver (rather than just a basket catch) but am hoping there's a more simple solution out there.
    Thanks for your reading.
    Something kind of like this (Mimaki Desktop CG60SL) but a printer, not necessarily a cutter.
    Dec 2009
    Aha... a label rewinder.
  1. Simple question: Hot roll vs cold roll steel
    By CuttersCov in forum MetalWork Discussion
    Last Post: 01-10-2013, 02:42 PM
  2. Roll threading 2-56 look issue
    By nfs7713 in forum Haas Mills
    Last Post: 10-08-2009, 05:42 PM
  3. Roll tapping.
    By Mitsui Seiki in forum G-Code Programing
    Last Post: 06-17-2008, 05:37 AM
  4. On A Roll - Another new machine
    By vacpress in forum DIY CNC Router Table Machines
    Last Post: 10-31-2007, 04:17 PM
  5. MPG's, Hacking or Roll y'er own or?
    By JerryFlyGuy in forum CNC Machine Related Electronics
    Last Post: 01-26-2007, 05:01 PM
