587,787 active members*
2,677 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Series 2 Knee to Column deflection
    May 2009
    15
    I measure .002 deflection at the knee when I run the Y axis between its full range. I tightened the gibs to the point where I could barely move the knee up and down the column, and measured the deflection to be the same (I loosened it after). I have also fully locked the column locks and again no difference. Is this deflection typical? Is there a solution? I have searched the forums for this topic and only found a post where someone suggested locking the column locks...
    May 2009
    15
    I think I found the problem. I just discovered there is a gib on both sides of the column for the ways that support that motion. I tightened both, and also fully locked the locks and now only measure .001"... Still seems high, but better.
  1. Newbie: Knee Mill or Square Column
    By Fraese in forum Uncategorised MetalWorking Machines
    Last Post: 01-08-2009, 04:47 AM
  2. Square column or small knee?
    By Fraese in forum Benchtop Machines
    Last Post: 01-08-2009, 04:03 AM
  3. Broken Knee / Column Gib-Strip
    By niggle in forum Bridgeport / Hardinge Mills
    Last Post: 05-04-2008, 09:10 PM
  4. Knee Mill vs Square Column Mill
    By SCzEngrgGroup in forum Bridgeport / Hardinge Mills
    Last Post: 11-10-2007, 01:27 AM
  5. one axis dro kit for knee on series 2
    By Cycle Start in forum Bridgeport / Hardinge Mills
    Last Post: 03-14-2007, 02:58 AM
