Well, I'm definitely a newbie again.
I have a pocket that I would like to cut out by simply running a contour around the inner walls -there will be a little island in the middle, which will fall out when I'm done, but if I use the roughing cycle/operation, EdgeCAM puts in these little swirl moves - without them the program is shorter by a minute or two - serious time when you think about a couple of hundred runs.
However, if I use a profile cycle/operation, there is no option for a ramp entry. How do I cut a contour with a ramped entry?
