587,424 active members*
3,331 visitors online*
IndustryArena Forum > Material Technology > Metallurgy > Correct material and process for compass needles?
    Sep 2006
    7
    Question Correct material and process for compass needles?
    What material and process is best for making compass needles?
    We are making some compasses to spec, but are stuck when it comes to the needle. The spec does not designate the material, just that it needs to be magnetic. Does anyone know a source of info, or have info, on how to make them?
    So far it seems they should be 1010 CRS, magnetized when hot. Supposedly they need to be low carbon so they don't harden when coming down from austinizing temperature. But that's just a guess.
    We'll stamp them (or machine them if necessary). But we're looking for the correct material and magnetizing process, and perhaps a gauss spec.
    TIA,
    Len
    PS: This is posted somewhere else, in a private forum. I thought I could post here as well because of the odds being very slim that one person would see both posts. If someone here is a member of the private forum, I apologize for double posting.
    Apr 2007
    777
    This is a shot in the dark, but I think you would want something with a high magnetic coercivity and a much higher magnetic remanence. I did 10 minutes of research in the Handbook of Chemistry and physics and the wikipedia on magnetic coercivity and I think that what you want is probably one of the Alnico technologies. They are likely to perform orders of magnitude better than 1010.
    You might try asking an apps engineer at http://www.dextermag.com/ as they make alnico which I think is probably a good choice.
    Cameron
  1. Knitting Needles
    By billybrown in forum WoodWorking Topics
    Last Post: 03-21-2009, 04:01 AM
  2. anyone know anything about in process gaging?
    By cncclimber in forum Okuma
    Last Post: 11-21-2008, 05:37 AM
  3. In the process
    By Smitty911 in forum Dolphin CAD/CAM
    Last Post: 05-10-2007, 06:34 AM
  4. Tig Process ??
    By millman52 in forum Welding Brazing Soldering Sealing
    Last Post: 04-30-2007, 07:41 PM
  5. Who can enlighten me how to process ultra-hard material?
    By TechDoor in forum Benchtop Machines
    Last Post: 11-30-2006, 03:41 AM
