586,657 active members*
3,685 visitors online*
    Jan 2009
    396
    mach3 Y axis 2 stepper 2 ballscrews setup
    how to setup mach3 mill running Y axis with 2 stepper motor + 2 ballscrews?
    Set up the second as A, B, or C axis. Make sure all settings are the same (except pins). Go to Config > Slaving and assign the slaved axis to Y.
    Jan 2009
    396
    Thanks ger21!
    just curious how did those people do it with 6th axis using 2 ballscrews n 2 motors on Y axis ? parallel port only have 12 outputs
    You can use two ports.
    Apr 2011
    I got d same problem and my second motor still not working though already Config > Slaving and assign the slaved axis to Y. Anybody knows how to set d others with relevant of slaving d same axis.
    4 ur info I'm using 4 axis TB6560 driver board.
  1. Z-axis setup/control in Mach3
    By Richotech in forum Machines running Mach Software
    Last Post: 08-10-2012, 05:49 PM
  2. Mach3 A axis (4th axis) setup?
    By cadcamslawek in forum Mach Software (ArtSoft software)
    Last Post: 01-18-2012, 03:23 AM
  3. Mach3 R3.00 Mill 4 axis Foam cutter setup
    By Andy Smith in forum Mach Mill
    Last Post: 01-25-2008, 02:19 PM
  4. Featurecam Lathe Setup X axis MAch3
    By whiteriver in forum FeatureCAM CAD/CAM
    Last Post: 02-21-2006, 12:04 AM
