587,427 active members*
5,278 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 10M, EMG Display On, EMG Button OK, Rev 6-29
    Jun 2009
    135
    Thank You GUHL
    We checked the EMG button and the relay it actuates. They are OK.
    We looked at the ladder diagram on he machine, but frankly it is way beyond our capabilities in that area, but we would like to know the logic flow that allows the control to come alive.
    The emergency button actuates a Relay, CR17, this is OK.
    A new relay did not help.
    This problem occurred after a total reload of all parameters by a qualified person who has sucessfully done this before.
    The machine appears OK except the EMG display on the bottom of the CRT stays on and the machine is dead.
    We are leaning toward some parameter that keeps the EMG on, but what one? Thanks.
    Aug 2007
    793
    Quote Originally Posted by JimBoyce View Post
    Thank You GUHL
    Check option relays. The option relays - are the software links in ladder. May be one wasn't set up. They are marked "OPx.x". The first "x" - number of byte, the second "x" - number of bit. Try to find one in EMG line of ladder. To set up push "NC/PC" -> software key "relay" (or "option relay" - don't remember exactly). Then set the proper bit in byte.
    Jan 2011
    Thank You GUHL
    mine did the same thing. PARAMETERS!!! i'm telling you check them or edit them.
  1. Fanuc O-MD prog ck display
    By yoshi900 in forum Fanuc
    Last Post: 10-15-2008, 11:35 AM
  2. Replies: 13
    Last Post: 02-19-2007, 06:09 AM
  3. Fanuc OT control Auto Button
    By thardy in forum Fanuc
    Last Post: 11-12-2006, 04:52 PM
  4. Position Display on fanuc 6m
    By fredf1 in forum Fanuc
    Last Post: 10-22-2005, 10:08 AM
