Hello, I have a home brew cnc router that worked fine till just recently. The z axis will not move down while running a program. The axis moves with the jog keys ok. I have noticed there is no holding torque on the motor while a program is running. Hit the stop button in master5 and the motor holds. I swaped the z and y axis and the problem moved so I think I can rule out the motor. Any ideas as to where to begin? Here is a sample file I was using. Thanks in advance.
