586,655 active members*
2,710 visitors online*
    Nov 2005
    5
    hold down plastic
    Hello everybody
    This is first time I have to doing machining on derlin/plastic I have to do machining outside profile & on center hole(9”) from 24”x24”x0.750” derlin /plastic what is the best way to hold down plastic. I don’t have any vacuum devices’. Please help me for which end mill I can use with recommended speed, feed, and depth of cut. Any suggestion helpful
    Mar 2006
    474
    Here's one way;
    Doublesided tape, and a few clamps around the outside. Cut the center hole, and move the clamps. The tape will keep your Delrin from moving while you shuffle clamps, then profile the outside.
  1. Hold to hold tool holder while loosening nut
    By NXTwoThou in forum CNC Tooling
    Last Post: 02-24-2009, 10:15 PM
  2. Plastic Hold down
    By vetteboy86 in forum Work Fixtures / Hold-Down Solutions
    Last Post: 01-11-2008, 02:07 AM
  3. vac hold down
    By woodman08 in forum Commercial CNC Wood Routers
    Last Post: 11-19-2007, 01:47 AM
  4. How do you get a hold of one cnc?
    By turboboy in forum OneCNC
    Last Post: 01-03-2007, 01:50 PM
  5. How to hold
    By MIKEB in forum Work Fixtures / Hold-Down Solutions
    Last Post: 09-05-2005, 02:50 AM
