I want to build a small radial engine , but the smallest plugs I have seen listed is 1/4 " And I will need smaller than that. What do you use as an insulator
Don't know how to make a ceramic insulator, but how about these plugs?
http://sparkplugs.morrisonandmarvin.com/
I've seen machinable ceramic... I think McMaster Carr sells it...
Here's a link.
http://www.mcmaster.com/#machinable-ceramics/=1zopf8
If you can get it, you could try Macor. It is a machinable mica based ceramic and I can tell you from experience, machines very well with carbide tooling. It has the electrical resistance you'd need but also very good thermal insulation and low thermal expansion.
bob2251, can you tell us anymore about the radial engine you are building?
I made about 10-15 a few years back. The trials were made of pink corian and stainless electrodes, which I gave away as trinkets to friends. The keepers were white with tungsten electrodes. Spark was decent!
Pink is nice on some things, but not my engine. LOL!
DC
The insolator well is drilled to a depth that leaves a flat inner face cap on the ground electrode end. I then screwed the threaded steel body from the underside of a 1/4" plate of aluminum held in my vise. The cap, errrr soon-to-be ground electrode setting proud above the plate was then CNC'd by a U shaped path, profiling the tang in one pass. Unscrew that one, swap it for another and hit the go button again.
The upper wall of the steel body is thin enough to swedge over(with a custom tool) after locktiting the corian insolator into the body for a good leakproof seal. The spark electrode is sized for length to set the spark gap, then locktited or superglued into place.
DC
Many thanks for the drawing and description. It's more than I expected and will tinker with these when I get a chance. I have looked for ignition coil winding info in the recent past but didn't find anything that I thought was useful.
CarveOne
CarveOne
The profiles don't really need to be so detailed. I used these as a self tutorial for programming a CNC lathe......while still being productive? LOL!
Check into the index on the Strictly IC website. There was a lengthy multi-part article on coil winding and possibly a build project of the winder IIRC.
By the way for those that had not heard, Robert Washburn, the owner and editor of Strictly IC passed on about a month or so back.
DC
You might want to check out this website
