587,518 active members*
3,559 visitors online*
Results 1 to 16 of 16
    Feb 2005
    10
    Cool Making Spark Plugs
    I want to build a small radial engine , but the smallest plugs I have seen listed is 1/4 " And I will need smaller than that. What do you use as an insulator
    Oct 2006
    708
    Don't know how to make a ceramic insulator, but how about these plugs?
    http://sparkplugs.morrisonandmarvin.com/
    Dec 2006
    603
    Quote Originally Posted by bob2251 View Post
    I made a spark plug that had a 6-56 thread. The insulator was made from Corian counter top material. The electrode was .020 nichrome wire super glued thru the corian. I dont have it any more because i dropped it and it broke.
    It worked!
    Mar 2006
    474
    I've seen machinable ceramic... I think McMaster Carr sells it...
    Here's a link.
    http://www.mcmaster.com/#machinable-ceramics/=1zopf8
    Dec 2006
    603
    Quote Originally Posted by vlmarshall View Post
    Here's a link.
    Looks like it would be good stuff. At 7 bucks an inch for 1/8 inch rod, i think i would stick with the corian. I got a 20 pound box on ebay for 8 bucks including shipping.
    Mar 2006
    474
    Quote Originally Posted by stevehuckss396 View Post
    Wow, I'll have to remember that one.
    Apr 2005
    862
    If you can get it, you could try Macor. It is a machinable mica based ceramic and I can tell you from experience, machines very well with carbide tooling. It has the electrical resistance you'd need but also very good thermal insulation and low thermal expansion.
    Dec 2006
    603
    Quote Originally Posted by LongRat View Post
    Again 7 bucks an inch for 1/8 inch. Corian is cheap and will live in a model engine for years.
    Nov 2005
    31
    bob2251, can you tell us anymore about the radial engine you are building?
    Aug 2005
    1622
    Here are some 1/4-32
    I made about 10-15 a few years back. The trials were made of pink corian and stainless electrodes, which I gave away as trinkets to friends. The keepers were white with tungsten electrodes. Spark was decent!
    Pink is nice on some things, but not my engine. LOL!
    DC
    Apr 2007
    8082
    Quote Originally Posted by One of Many View Post
    DC
    How do you attach the ground electrode? Arc weld it with a power supply of some sort using a fixture to hold the parts in place?
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    Aug 2005
    1622
    Quote Originally Posted by CarveOne View Post
    CarveOne
    The insolator well is drilled to a depth that leaves a flat inner face cap on the ground electrode end. I then screwed the threaded steel body from the underside of a 1/4" plate of aluminum held in my vise. The cap, errrr soon-to-be ground electrode setting proud above the plate was then CNC'd by a U shaped path, profiling the tang in one pass. Unscrew that one, swap it for another and hit the go button again.
    The upper wall of the steel body is thin enough to swedge over(with a custom tool) after locktiting the corian insolator into the body for a good leakproof seal. The spark electrode is sized for length to set the spark gap, then locktited or superglued into place.
    DC
    Apr 2007
    8082
    Many thanks for the drawing and description. It's more than I expected and will tinker with these when I get a chance. I have looked for ignition coil winding info in the recent past but didn't find anything that I thought was useful.
    CarveOne
    CarveOne
    Aug 2005
    1622
    The profiles don't really need to be so detailed. I used these as a self tutorial for programming a CNC lathe......while still being productive? LOL!
    Check into the index on the Strictly IC website. There was a lengthy multi-part article on coil winding and possibly a build project of the winder IIRC.
    By the way for those that had not heard, Robert Washburn, the owner and editor of Strictly IC passed on about a month or so back.
    DC
    Apr 2007
    8082
    DC
    One of these days I will CNC a small lathe. Not sure I want to do it to my 12x36 lathe. That one needs to remain manual.
    I'll check out the site.
    CarveOne
    CarveOne
    Dec 2008
    22
    You might want to check out this website
  1. THK rail plugs
    By walter in forum Linear and Rotary Motion
    Last Post: 04-28-2015, 10:31 PM
  2. Laser tube discharges in a spark
    By buc in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2009, 12:28 PM
  3. Spark Testing Steels
    By Barry_ward in forum MetalWork Discussion
    Last Post: 01-25-2007, 06:19 PM
  4. Something to spark creativity :)
    By slp_prlzys in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-23-2006, 01:47 AM
  5. Have a problem with a Spark
    By watzmann in forum Community Club House
    Last Post: 05-09-2006, 09:34 AM
