587,080 active members*
3,158 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > THB6064H(4.5A)-Stepping Motor Driver IC 4.5amp
Results 161 to 180 of 185
Threaded View
    Oct 2005
    36
    hi
    The THB6064H is a PWM chopper-type sinusoidal micro-step bipolar stepping motor driver IC.
    It supports 8 kind of excitation modes and forward/reverse mode and is capable of low-vibration, high-performance drive of 2-phase bipolar type stepping motors using only a clock signal.
    Features
    • Single-chip bipolar sinusoidal micro-step stepping motor driver
    Weight: HZIP25-P-1.27: 9.86 g (typ.)
    • Uses high withstand voltage BiCD process: Ron (upper  lower) = 0.4 �� (typ.)
    • Forward and reverse rotation control available
    • Selectable phase drive (1/2,1/8,1/10, 1/16, 1/20, 1/32, 1/40, 1/64 step)
    • High output withstand voltage: VDSS = 50 V
    • High output current: IOUT = 4.5 A (peak)
    • Packages: HZIP25-P-1.27
    • Output monitor pins (DOWN / ALERT)
    • Equipped with reset and enable pins
    • Built-in thermal shutdown(TSD) and over-current detection(ISD) circuit
    *: Since this product has a MOS structure, it is sensitive to electrostatic discharge. These ICs are highly sensitive to electrostatic discharge. When handling them, please be careful of electrostatic discharge, temperature and humidity conditions.
  1. TB6560HQ-Stepping Motor Driver IC 3.5amp
    By NASR1 in forum Open Source Controller Boards
    Last Post: 03-30-2015, 10:02 AM
  2. Stepping Motor Driver IC THB6064H
    By lihaijiang in forum Engraving Machines
    Last Post: 07-07-2009, 03:49 AM
  3. THB6064H stepping Motor Driver IC4.5A
    By lihaijiang in forum News Announcements
    Last Post: 06-22-2009, 03:29 AM
  4. Stepping Motor Driver
    By MR MOTION in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 06:13 PM
  5. 80V 6A Micro stepping Motor driver
    By eded59 in forum Stepper Motors / Drives
    Last Post: 07-31-2007, 03:43 AM
