585,919 active members*
3,474 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > THB6064H(4.5A)-Stepping Motor Driver IC 4.5amp
Page 1 of 10 123
Results 1 to 20 of 185
    Oct 2005
    36
    hi
    The THB6064H is a PWM chopper-type sinusoidal micro-step bipolar stepping motor driver IC.
    It supports 8 kind of excitation modes and forward/reverse mode and is capable of low-vibration, high-performance drive of 2-phase bipolar type stepping motors using only a clock signal.
    Features
    • Single-chip bipolar sinusoidal micro-step stepping motor driver
    Weight: HZIP25-P-1.27: 9.86 g (typ.)
    • Uses high withstand voltage BiCD process: Ron (upper  lower) = 0.4 �� (typ.)
    • Forward and reverse rotation control available
    • Selectable phase drive (1/2,1/8,1/10, 1/16, 1/20, 1/32, 1/40, 1/64 step)
    • High output withstand voltage: VDSS = 50 V
    • High output current: IOUT = 4.5 A (peak)
    • Packages: HZIP25-P-1.27
    • Output monitor pins (DOWN / ALERT)
    • Equipped with reset and enable pins
    • Built-in thermal shutdown(TSD) and over-current detection(ISD) circuit
    *: Since this product has a MOS structure, it is sensitive to electrostatic discharge. These ICs are highly sensitive to electrostatic discharge. When handling them, please be careful of electrostatic discharge, temperature and humidity conditions.
    Jan 2007
    97
    nice.
    from where did you guys get these chips.i searched like hell on net but couldn't found one source.
    Apr 2006
    169
    I hate to be the bearer of bad news ????
    http://bjbyds.com.cn/ShowPro.asp?id=145
    Feb 2007
    4553
    Question
    Have you tested this board?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2006
    169
    (wrong)(wrong):withstupi
    I think it is a false or scam no mentioning of the driver except on chinese pages also i
    couldn't found it on toshiba (nuts)
    http://www.toshiba-components.com/mo...r_drivers.html
    http://www.semicon.toshiba.co.jp/ope...h/resultDo.jsp
    Feb 2005
    122
    why do you think that this IC it's made by Toshiba ?
    http://www.bjbyds.com.cn/En_ShowPro.asp?id=144
    The logo from IC doesn't seems to belong to Toshiba - probably it's made (or rebranded ?) by a chinese company. On above site it seems to have more options.
    Apr 2006
    169
    http://www.bjbyds.com.cn/En_ShowPro.asp?id=144 (wedge)
    4. Application Circuits
    The application circuits shown in this document are provided for reference purposes only. Thorough evaluation is required, especially at the mass production design stage.
    Toshiba does not grant any license to any industrial property rights by providing these examples of application circuits.
    Jun 2009
    52
    good news THB6064AH Stepper motor driver chip All the information
    1.THB6064AH
    The THB6064AH is a PWM chopper-type sinusoidal micro-step bipolar stepping motor driver IC.
    Attached Files Attached Files
    Jun 2009
    52
    THB6064AH PCB
    THB6064AH PCB picture
    Attached Thumbnails Attached Thumbnails THB6064AH ENG PCB.jpg   THB6064AH ENG Schematic diagram.jpg
    Jun 2009
    52
    Quote Originally Posted by hesham morsy View Post
    Recommend an official website about THB series chips to you: [url=http://www.hhbytech.com/en]
    Nov 2011
    0
    Quote Originally Posted by lihaijiang View Post
    Good news.
    Nov 2011
    0
    You are so kind, I can load many documents about stepper motor driver IC from this website.
    Thanks a lot.
    This forum is so useful for me.
    May 2005
    1397
    Price? Availability?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Nov 2011
    0
    Quote Originally Posted by James Newton View Post
    I inquiried and got the quotation from that company.They have just reduced the price.
    THB6064AH IC -----6.6USD/piece
    PCB----------------23USD/piece
    May 2005
    1397
    Quote Originally Posted by Jerry888 View Post
    At what quantity? And what are the shipping costs?
    So.... this is a single, small, Chinese company which has produced a chip like the TB6560, but with some extra features, and are selling it directly... it is NOT available from distribution, only direct? And the company is one we have never heard of? And no one has tried this driver or the chip?
    This is very scary. high risk/reward curve. Bleeding edge, where you bleed. Anyone willing to take a chance on it?
    May 2005
    81
    and/or bootleg IP
    Jun 2009
    52
    James Newton:
    I will try my best to answer all your queries:
    THB6064 is a new type chip from Beijing Haihua Boyuan Science Technology and Development Co.,Ltd., which is customized product designed and produced by TOSHIBA Semiconductor Company. In TOSHIBA company, it has an internal model (TB6564AHQ), so you can’t find any documents about THB6064AH.However, you can find the announcement about THB series chip by TOSHIBA Semiconductor Co.Ltd.
    THB6064AH offers simple peripheral circuit, more selectable phase excitation, high output current and high driver voltage, as TB6560. Its excellent performance is a quantum leap ahead of TA8435 AND TB6560HQ.Therefore, it is an updated product. Through Vref circuit, you can adjust the multi-groups driver current. When there is no impulse to input, DOWN will output the low level. Connect external resistor to reduce the Vref voltage. At the same time, the operation current of static motor was reduced. Through FDT terminal, you can set the decay mode (Fast-decay mode; Slow-decay mode; Mixed-decay mode). Through UVLO detection, you can adjust the supply voltage Vc of the logic circuit .If Vc below3.9V, close the output; if Vc above 4.0V, the protective function will be on. You can design a circuit easily to protect the driver by overheating and over current detection.
    Attached Thumbnails Attached Thumbnails 6064QQ1.jpg   6064QQ2.jpg   6064QQ3.jpg   6064QQ4.jpg
    Jun 2009
    52
    Nov 2011
    0
    Smile
    James Newton
    Q:At what quantity? And what are the shipping costs?
    A:quantity:100pcs shipping cost :freight collect( in the same country).
    You are also interested in this new product.Hahaha......
    May 2005
    1397
    Yeah, it looks like a great chip, its just a trust issue. And that is a serious problem. Do you have a sample program? Has anyone in the USA tested it?
Page 1 of 10 123
  1. TB6560HQ-Stepping Motor Driver IC 3.5amp
    By NASR1 in forum Open Source Controller Boards
    Last Post: 03-30-2015, 10:02 AM
  2. Stepping Motor Driver IC THB6064H
    By lihaijiang in forum Engraving Machines
    Last Post: 07-07-2009, 03:49 AM
  3. THB6064H stepping Motor Driver IC4.5A
    By lihaijiang in forum News Announcements
    Last Post: 06-22-2009, 03:29 AM
  4. Stepping Motor Driver
    By MR MOTION in forum Stepper Motors / Drives
    Last Post: 05-17-2009, 06:13 PM
  5. 80V 6A Micro stepping Motor driver
    By eded59 in forum Stepper Motors / Drives
    Last Post: 07-31-2007, 03:43 AM
