586,842 active members*
2,994 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Router Laser? Cutter? CNC Recommend PLease
    Apr 2009
    I am in a total loss and tangent in looking for what I seek
    I am a scrtach builder mainly architectural models and other scrtch built diromas and panels for amusement parks etc.
    I am not sure if I need a laser or router or what?
    Here are the basics I want to cut
    Wood or foam no greater than 3"
    Styrene no greater than 1/4
    Acrylic no greater than 1/4
    Metal not a priority in this but would be nice(aluminum no greater than 1 inch)
    Id like to etch or score, would also like to 3d
    Base size 24"x36 i could go larger or a little smaller but not much smaller
    I am new to CNC but familiar with CAD and computers
    ANY recommendations would be nice Local US i would rather not have a Overseas machine
    I am not sure what to get I would like to keep it under 5k
    less is always better though
    Many Thanks in advance!!!!!
    I am just overwhelmed by the options....
    Jul 2008
    776
    Router , no doubt. Concerning price - looks like only Chinese router fit this limit and my advice buy it from local dealer who will provide installation, training and support
    Apr 2009
    So you think a Router?
    Will the router melt the acrylic?
    etc?
    Jul 2008
    776
    I am sure about router
    Concerning melt - everything depends from proper tool choice and parameters setting. On router for 5000 USD you can't get only clear edge while cutting acryl.
    Apr 2004
    5742
    For 3d and anything approaching 3" thick, you'll need a router. Laser cutters (at least the ones in your budget) are 2d only and won't cut much over 1/4". But I could see fitting a small CO2 laser outboard on your spindle's headstock and using it for the 2d cutting it sounds like you want to do about as much as the routing. It cuts acrylic and cardboard quite cleanly; much better than a router bit will.
    Andrew Werby
    www.computersculpture.com
  1. CNC Laser cutter versus CNC Plasma cutter?
    By squale in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-24-2020, 02:14 AM
  2. CNC LASER CUTTER/PLASMA/ROUTER DESIGN
    By protomate in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-25-2008, 07:56 PM
  3. Which CNC Router plans would you recommend(HobbyCNC, Rockcliff, or JGRO?)?
    By LaughingCheese in forum DIY CNC Router Table Machines
    Last Post: 08-10-2008, 04:57 AM
  4. Why buy a Laser cutter when you can modify a laser engraver.
    By spacifique1 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-13-2007, 08:39 PM
