587,372 active members*
3,452 visitors online*
    Dec 2007
    73
    Rapid tool moves when not cutting?
    When my CAM program creates code for my lathe there are lots of G01 tool moves that are outside of part profile that I have changed to (G00) rapid tool moves.
    Is there a reason these tool moves are written by CAM as mostly G01 and not G00? I have significantly cut run time down by changing non engaged tool moves to G00. Is there more of a potential of position loss, inaccuracy or lead screw wear with lots of rapid tool moves or a reason all non engaged tool moves should not be rapid?
    Mike
    Mar 2005
    988
    For the most part, this is probably a condition of how you have your CAM system set up. For example: Lead In/Out set too far, Approach/Retract settings too far, a switch in the CAM system to allow for rapid moves in between cuts.. etc, etc. The odds are, the CAM system is posting what you're telling it to do. What CAM system are you using?
    It's just a part..... cutter still goes round and round....
    Dec 2007
    73
    Visualturn, Thanks for the advice
    I will look into settings in MOPs.
  1. Rapid tool changer
    By HakBot in forum Benchtop Machines
    Last Post: 12-15-2009, 04:58 PM
  2. Newbie - torch dragging on rapid moves
    By bad-rat-57 in forum Waterjet General Topics
    Last Post: 07-10-2008, 12:45 PM
  3. rapid tool changer
    By heilcnc in forum Benchtop Machines
    Last Post: 06-14-2007, 04:44 PM
  4. Cycle Time for Rapid Moves and Tool Changes V9.1.1012 Turn
    By jmullett in forum Dolphin CAD/CAM
    Last Post: 02-07-2007, 11:32 AM
  5. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
