587,659 active members*
3,289 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Cycle Time for Rapid Moves and Tool Changes V9.1.1012 Turn
Results 1 to 2 of 2
    Nov 2004
    164
    Thought I'd cross post here as well. The traffic on yahoo groups does not seem to be any more current than this forum.
    Could someone tell me if there is a parameter somwhere to define the speed of the rapid moves or the time for the turret to change tools so that the estimated cycle time is calculated more accurately? When I look at the table presented in View->Cycle Time Data it appears that the rapid distance is presented correctly however the time estimate is 0 seconds. It also appears tool changes are generically assigned a time of 1 second.
    I suppose that an acceleration rate should also be defined for each axis as well, however the algorithm is probably not that sophisticated for an estimate.
    Cycle Time Evaluation
    In response to recent interest I will post an example of
    a Post Processor which produces an estimated cycle time,
    explanatory notes will be included.
    Regards
    Michael
    Dolphin CAD CAM Ltd
    Dolphin CAD CAM Ltd
  1. Canned cycle face turn problem
    By Wiseco in forum FeatureCAM CAD/CAM
    Last Post: 12-22-2008, 08:30 PM
  2. Rapid moves G00
    By dicksonhof in forum Mach Software (ArtSoft software)
    Last Post: 11-07-2006, 04:21 PM
  3. Long cycle time?
    By CNCtoday in forum Polls
    Last Post: 09-28-2006, 05:28 PM
  4. cycle time macro program
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-29-2006, 07:33 PM
  5. cycle time formula
    By cncsdr in forum MetalWork Discussion
    Last Post: 12-30-2005, 01:21 AM
