586,635 active members*
3,123 visitors online*
Thread: Helical Help
    Apr 2007
    8
    Helical Help
    Just started working at this new place and we're upgrading cutters. We jumped from 12 IPM to 194IPM, Now here's the kicker, Step is .05 from .200, so the guys are having to reprogram all the programs. The way they were doing it was say with a XYIJ and z-.2 then next line z-.4 and so on till the pockets cut thru. Now we are doing .05 depth, and in a 3" plate that's adding a lot of lines and that's a mistake waiting to happen. I know you can use a L word and G91 but can't remember how to do it(been doing CAM for to long ) Can someone give me and example that I can follow that will work on a Fanuc 18i and or a Mazak? Thanks in advance....
    May 2007
    781
    This is quick and dirty but it give an idea to start with.
    Uses macro B not simple loops.
    Code:
    #100=.5(RADIUS)
    #101=0.01(START DEPTH)
    #102=-1.5(END DEPTH)
    #103=-0.05(STEP SIZE)
    #104=#101(SET CURRENT DEPTH)
    (DO A G52 LOCAL WORK OFFSET HERE)
    (IF YOU WANT TO MAKE A HOLE SOMEPLACE)
    (OTHER THEN THE CURRENT WORK OFFSET)
    (ZERO POSITION)
    G0X#100Y0.0
    G0Z[#104+0.1]
    G1Z#104F200.0
    #104=[#104+#103]
    WHILE [#104 GT #102] DO1
    G3I[-#100]Z#104F100.0
    #104=[#104+#103]
    END1
    G3I[-#100]Z#102F100.0(LAST STEP)
    G3I[-#100]F100.0(CLEANUP)
    G1X0Y0Z[#102+0.01]
    G0Z[#104+0.1]
    G52X0Y0
  1. MV 35/40 Helical Interpolation
    By Millem in forum Uncategorised MetalWorking Machines
    Last Post: 12-12-2007, 03:54 PM
  2. Helical Boring Help
    By Blosser5 in forum MetalWork Discussion
    Last Post: 11-30-2007, 03:03 AM
  3. Helical Milling
    By binzer in forum GibbsCAM
    Last Post: 03-30-2007, 10:39 PM
  4. Helical couplers for $5 !!!!!!
    By ger21 in forum DIY CNC Router Table Machines
    Last Post: 03-27-2007, 09:58 PM
  5. G2/g3 Helical In Yz(g19)
    By leggetmachine in forum G-Code Programing
    Last Post: 03-23-2006, 05:48 AM
