586,536 active members*
3,063 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Vertical Mill, Lathe Project Log > HARBOR FREIGHT small round column mill to a square column conversion.
Results 1 to 20 of 26
    Apr 2003
    348
    First of all I would like to say, I wouldn't recommend this mill for DIY unless you can live with the factory tolerances of the machine, table not flat by .012 had to recut and regrind pretty much every surface on it, some of the critical areas and surfaces of the machine out by as much as .030 in a 4 inch distance. So with that said you would need a full machine shop to recondition the machine and during some testing I found that there was no way to get a very good cut with a 3/8 to 1/2 end mill, side cutting 6061 T6 alum. which is the main reason I am converting to square column. It hasn't been tested yet but I suspect this is the main culprit of the vibration and bad surface finish, may have to make a new spindle also, have not got that far yet. X Y Z Travels have all been added to. IM not to good a writing stuff up but I wanted to share my drill/mill with CNC ZONE click on link to see pics
    http://webpages.charter.net/ms61/
    4826
    There's two kinds of cheap: Ebay cheap, and then Cheap cheap.
    Nov 2004
    260
    Awesome, seams you are very skilled and had all the tools needed.
    I wonder how much this conversion has cost you Parts and Time wise?
    Looks like your allmost done with this send us some Pic's when completed.
    Good Job
    Apr 2003
    348
    HARBOR FREIGHT small round collum drill/mill
    SPECIFICATIONS: out of the box
    Table Size: 16.5 x 6.06
    X Travel: 9”
    Y Travel: 5”
    Z Travel: 12”
    Spindle MT2
    Spindle stoke 3-3/8"
    1/2 HP 120 VaC MOTOR
    Spindle RPM: 12 speed 300 to 3800 rpm
    column dia. 2.830
    NEW SPECIFICATIONS:
    Table Size: 20.5 x 6.06
    X Travel: 13.000”
    Y Travel: 6.750”
    Z Travel: 18.000”
    column size .250 x 4 x 6 x30 with Rails 5x6 :cheers:
    Rail Type: IKO LRW 20
    Rail Length: 32 1/2" Long
    4 Bearings
    Bearing Type: IKO LRW 20
    Length Of The Bearing: L 4 1/8 In x W 2 3/4 In
    Lead-screw: Ball Screws for all X, Y and Z
    Double acting, angular thrust bearings on all axis.
    Spindle motor:McMillan Electric Permanent magnet MOTOR
    2-1/4 HP at 260 VDC int.
    1-1/8 at 130 VDC cont.
    95-260 VDC
    5 Amps
    0-5100 RPM
    Spindle RPM: low range 0-5000 RPM high range 0-10000
    serpentine 6 rib Micro-V belt
    Spindle: MT2
    Servo Motors: Clifton 30V DC Servo Motors
    360 oz/in peak torque
    USDigital Encoder:250 CPR USDigital
    drives: Gecko G320 servo drives
    pc controler: amd k2 500 mhz
    stepper softwear: Quickstep
    Mar 2004
    564
    Nice job!
    I enjoyed the pic.'s
    I always learn something new by looking at other people's set-up's.
    What was the actual encoder you used from usdigital?
    Apr 2003
    348
    The Encoder is a US Digital
    E2 - (CPR 250) - (Shaft Diameter.250) - (Options-G)This option includes molded ears on the E2 base which enable it to be mounted to a 1.812" diameter bolt circle. COST $39.00 / 1
    So my order number look like this ( E2-250-250-G )
    Apr 2003
    348
    Cheap-O-matic
    Apr 2003
    348
    Added new pics to photo gallery, just about got the Z done over the weekend
    http://webpages.charter.net/ms61/photo.htm
    4826
    Looks nice, Moto. Do you feel a bit of an urge to worship something that tall when you get near it?
    Apr 2003
    348
    Thanks and yes I do kind of.
    Apr 2003
    348
    Got her running needs a few more covers for the belts and make my home made spindle tach and it will be done ,I cut a test block at 8000 rpm ,65 ipm
    dc motor was getting hot might have to add fan to motor.
    here is some new pics :cheers:
    http://webpages.charter.net/ms61/new_page_1
    1880
    welding
    great job man..
    I got a couple of questions for my own mill.
    1. what weld rod did you use to weld the crapy cast iron to your steel plate??
    2. what type of motor did you use for your spindle.
    3. did you have any problems spining those stock mill bearings to 11000 rpm?
    Hope mine comes out half that nice and I will be a happy man!
    Apr 2003
    348
    1. what weld rod did you use to weld the crapy cast iron to your steel plate?? A nickel based stick rod that someone at my work gave me the identification of the rod was rubbed off.
    2. what type of motor did you use for your spindle. The spindle motor is a surplus tread mill motor I got two of them for nine dollars each the spindle will go from around 300 to 11700 with a single belt ratio and still has plenty of power at the 1000 rpm range.
    3. did you have any problems spinning those stock mill bearings to 11000 rpm? Yes, they will get hot but there cheep, they run a little warm at 8000 and work great at 5000 it just depends on what load your putting on them most of my work is done with 1/8 to 1/4 inch endmills which can't produce much load. I do have future plans maybe if I have time to make a better spindle with angular contact bearings with a r8 taper.
    Apr 2003
    348
    update
    Just got one of the last parts needed to make a windows based step controller super fast
    with out all the pc timing issues.Its called Qstep with a PulsePacer my mill will easy make
    10" moves at 200 + IPM, it takes 3 sec to go 10" start to stop im very happy with the speeds
    im getting from the PulsePacer. I was getting around 40 ipm from my 500 MHz pc with out the
    PulsePacer using just windows based step controller software.
    PulsePacer is a independent timing circuit that is buffered from your computer operating
    system
    PulsePacer pic http://webpages.charter.net/ms61/pp1.JPG
    http://webpages.charter.net/ms61/pp2.JPG
    1880
    I am well on my way to a similar mill to yours (although i am using servos) I have already obtained a treadmill 2.5hp motor before your post (we think along similar lines
    the pulse paser, can it be driven buy mach2, turbocam or any of the other g-code interpreters? and if not does it come with its own software..
    by the by where'd you go for so long?
    thought the thread was dead.
    Apr 2003
    348
    I had to do some major home remodeling took up all my spare time :tired:
    am using servos and a treadmill 2.5hp motor
    The PulsePacer comes with its own software I dont beleave it will work with other softwares.
    http://cpwojcik.home.att.net/Qstep/Quickstep_CNCx.html
    1880
    very cool. let me know how you like the software.. seems primitive but the proof is in the machining.
    michael. t.
    Apr 2003
    348
    It was designed for first time users with a simple interface in mind and in order to keep it
    simple tool catalogs and tool offsets were not put in the program.most of the time with a
    homebrew cnc mill with no tool changer and making small simple parts you don't need all the
    bells and whistles,and if you get in a spot were you need to comp your tool in or out I do
    it from with in my cad software and repost it.I have been using Qstep for 2 years and I like
    it,and now its just a lot faster with the PulsePacer add on hardware kit.
    The opinions expressed in this post are my own and are not necessarily those of CNCzone or Qstep.
    Apr 2003
    348
    1880
    very cool. I am just getting into the rc car thing. and have bought a mamouth. It was one of my insperations for making a home mill. (even though I own a shop- My wife and kid were wondering who I was! )
  1. Biggest Square Column Bench Mill in the US.
    By IndHobby in forum News Announcements
    Last Post: 05-04-2013, 12:16 AM
  2. Square Column Mill/Drill Conversion
    By Jay Kyle in forum Vertical Mill, Lathe Project Log
    Last Post: 08-23-2005, 07:42 PM
  3. square column mill conversion
    By triberman in forum Benchtop Machines
    Last Post: 07-27-2005, 02:00 AM
  4. Tree Mill conversion Questions
    By Flyinfool in forum Uncategorised MetalWorking Machines
    Last Post: 05-28-2005, 04:37 AM
