why does the info pdf say to not switch the power supply off on the dc side and only kill the power supply via the ac input or it will damage the drive? I was about to order one but stopped due to this...i run pure dc no power supplies.. i use a bank of 8 trojan 125t deeps cycle 6v batteries for a 48v supply i started using this after two problem found with switching power supplies i had a a weird hi-pitch noise coming from my steppers and losing steps during a diag of the system i disconnected the power supply and used too car batteries i had laying around instantly the steppers where whisper quiet and ran way cooler, the miss steppes turned out to be something else but love how smooth and quiet and cooler steppers run on battery dc vs a switching power supply....I've tryed 3 different power supplies and there is no comparison batteries are better, so that said and the fact i have 800 dollars of battery's set up to run 3 other mills why can i not kill the dc power on a g540? i do on my other drives? when i shut them down??
