587,541 active members*
7,180 visitors online*
    Sep 2003
    1475
    Question Bent Too Much?
    I just received a 3' piece of 1/2 10 1 start acme rod that has a bend in it, and I think it is too much, but would like more opinions before I call the supplier for a replacement. It might be worse if I try to straighten it.
    I measured it by supporting the ends and placed a dial ind. in the center resting on a metal flat so the threads would not infulence the reading and saw 0.063" of wobble.
    Aug 2005
    1622
    Not surprising if it is mild steel 3' of rolled thread. Hardened and Ground, I'd expect better of. Chances are you might get no better, no worse in exchange unless you spec it with additional charges if they offer selective tolerances or straightening services.
    1/2" over 3 ft should bend easily. I have straightened 3/4 with a rubber mallet in a lathe chuck advancing it out 1 foot or less at a time, flipping it end for end just past half way out. The stuff is soft enough to make run true on center. Worked goodnuff for my needs on a 3' drill press table jack. But then, it weren't spinning at 1200rpm either.
    DC
    Sep 2003
    1475
    Smile Got it down to 0.006" Good enough for my application
    Quote Originally Posted by One of Many View Post
    DC
    Thanks DC
    I gave it a try and after a few attempts I got it down to 0.006", which is good wnough for me.
    Hager
  1. Bent Exhaust Valve
    By Soultaker696 in forum Bending, Forging, Extrusion...
    Last Post: 08-12-2008, 04:18 AM
  2. Need header tubes bent
    By RickDLance in forum Bending, Forging, Extrusion...
    Last Post: 02-16-2008, 04:57 AM
  3. Mandrel Bent 4x2 316 wall...
    By VinceSRC in forum Bending, Forging, Extrusion...
    Last Post: 02-02-2007, 02:22 PM
  4. RFQ: Bent Aluminum Part
    By lerman in forum Employment Opportunity
    Last Post: 04-21-2006, 08:15 PM
  5. RFQ- Need 3/32" wire bent
    By cncadmin in forum Employment Opportunity
    Last Post: 12-19-2005, 03:32 AM
