586,700 active members*
2,834 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > breakout board with spindle speed control
Results 1 to 7 of 7
    Feb 2009
    23
    Hey everyone,
    Need some advice!
    I want to by a breakout board with spindle speed control, With MACH3 support!
    Anyone got any suggestions ?
    Thanx
    George!
    Hi George
    Try cnc4pc.com and these do a control board as well www.DamenCNC.com
    Hope this helps
    Andy
    Feb 2009
    23
    thanx Andy for the links.
    what do you think about the "C11 - Multifunction CNC Board" http://www.cnc4pc.com/Store/osc/prod...products_id=46
    Jun 2004
    6618
    I used a different speed control board from them. Not built in. I worked, but with my motor controller for my treadmill motor, I kept getting some loping in the motor either at high speed or low speed depending on the Mach settings.
    I wound up using the smaller controller from Homann Designs.
    They work very well. Very small too. I use them on my lathe and my mill.
    The part you mentioned though looks like a good option. Nice to have all that onboard.
    Lee
    Mar 2008
    3655
    Be very careful with a BOB integrated speed control. If you connect it wrong or do not isolate with separate power supply, you can blow the whole BOB.
    What machine are you going to use this on?
    CR.
    Hi George
    The C11 Board looks good, thats the board I will look to buy when I upgrade to a HF spindle, at the moment I use the C10 board which I have had no problems with at all.
    Andy
    Apr 2007
    327
    I have a brand-new, never been used C11. I ended up going with a Gecko G540 and don't need a separate bob. If you are interested send me a pm. Since it's never been used, I'd like to get about $115 plus shipping, but make me an offer...
    Gary
  1. Need Breakout board to control Mach3
    By Mongkol in forum CNC Machine Related Electronics
    Last Post: 04-19-2008, 06:38 PM
  2. Replies: 2
    Last Post: 01-24-2008, 11:33 PM
  3. Router Speed Control + Mach3 + Breakout Board
    By Dingo745 in forum CNC Machine Related Electronics
    Last Post: 06-20-2007, 02:58 AM
  4. BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial?
    By peter.blais in forum Bridgeport / Hardinge Mills
    Last Post: 08-08-2006, 09:29 AM
  5. Control panel w/ Gecko 202, Campbell breakout board
    By Norsksea in forum CNC Machine Related Electronics
    Last Post: 01-28-2006, 01:16 AM
