586,792 active members*
2,748 visitors online*
Thread: Ezpath
    Nov 2005
    244
    Ezpath
    Is anybody using Featurecam to program and post to a Bridgeport Ezpath lathe?
    If so is it true you can post either conversational or gcode?
    Thank You
    Sep 2003
    363
    A few years back I used FeatureTurn to program an EZPath lathe. The control we had would read both G-code and conversation. I always used the conversation post. It worked just fine after a few minor changes to the post processer.
    Gary
  1. Ezpath Data Inquieytigation
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 01-18-2009, 07:12 AM
  2. EZPath II CSS problem
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2008, 07:43 PM
  3. ezpath fault
    By evo123 in forum Bridgeport / Hardinge Mills
    Last Post: 06-30-2008, 09:42 PM
  4. Ezpath Iiis Error Msg
    By Zombiestomp in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2007, 03:08 PM
  5. Bridgeport EZPath help needed!
    By VSMIGuy in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2007, 12:58 AM
