587,322 active members*
3,360 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Thread Milling - Cnc Program Developer - New Release
Results 1 to 1 of 1
    Apr 2008
    12
    The latest release of Cnc Program Developer (2.1.0.6) is available.
    The new release includes code macros for thread milling, boring and setting grid patterns for drilling and tapping with a corner origin.
    The thread milling code macros allow you to produce the code for inside diameter and outside diameter. You can set the pitch, thread length, z depth to the bottom of the thread and a finish cut thickness.
    CodeCam
    Cnc Program Developer produces the code that gets run on the machine. You design with operations that have a one-to-one correspondence to a machining operation. You are machining the part in the design process with the code produced by the code macros.
    The program is 3 axis (x, y, and z). Our structured cnc file format is both Haas and Fanuc compatible.
    You can produce the code quickly and easily with our code macros. Code macros are available for:
    - boring
    - chamfering
    - countersinking
    - drilling
    - milling - internally
    - milling - externally
    - peck drilling
    - spot drilling
    - tapping
    - thread milling
    More information, example videos and a trial are available at the web site:
    Http://www.cncprogramdeveloper.com
    The jpeg examples are the result of typical maching using Cnc Program Developer.
    Attached Thumbnails Attached Thumbnails CameraFinish.jpg   RevNews_ThreadMill.jpg   RevNews_BoringCircle.jpg   RevNews_GridCorner.jpg
  1. Thread Mill Program
    By october in forum G-Code Programing
    Last Post: 07-20-2016, 02:36 AM
  2. Cnc Program Developer - Software for Haas and Fanuc mills
    By John Walker in forum News Announcements
    Last Post: 01-06-2009, 03:17 AM
  3. 1/4 NPT External thread program
    By JerryH in forum G-Code Programing
    Last Post: 08-28-2008, 01:37 PM
  4. need help on program 1/2-4 2 star thread
    By plast744 in forum Haas Lathes
    Last Post: 12-04-2007, 07:30 PM
  5. 2-1/2 - 8 NPT Thread Mill Program
    By wesleybridgepor in forum MetalWork Discussion
    Last Post: 11-30-2006, 11:56 AM
