As Geof says, you should be OK without any extra circuitry etc.
I have run European rated equipment without any perceptible sign of difference, you will get extra rpm, in the case of the saw this will offset any drop in current.
If it is a Capacitor start motor, it should be OK, if capacitor start & cap run, you MIGHT have to decrease the run Cap. slightly, most likely not.
Al.
