586,744 active members*
5,652 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Stepper motor only turns one way
Results 1 to 7 of 7
    I bought a kit from keling inc to convert a X3 mill to cnc. I wired everything up according to their wiring diagram to bench test the motors(I don't have motor mounts for my mill yet). But when I hookup to mach3 and try and jog the motor will only turn one way and will not reverse. I've double checked all my wiring and can't find the problem. Any ideas? Thanks!
    Gray
    My advice is worth less then you paid for it.
    Mar 2008
    3655
    Hi Gray! Open Mach3. Click on config. Click on ports & Pins. Click on Motor outputs. Step pins should be set to 2, 4, 6, 8. Direction pins should be set to 3, 5, 7, 9. All axes should be set to port 1.
    CR.
    cr, YOUR THE MAN!!!!!!!!!!! she turns both ways now.
    Gray
    Mar 2008
    3655
    Glad I could be of help, Gray. What motors/drivers/ power supply are you using?
    CR.
    For the X and Y axis I'm using NEMA 23 425 oz-in steppers from Kelling. I'm using a NEMA 34 640 oz-in stepper for the Z axis. The driver is a KL-6050 from kelling.
    EDIT-Power supply is a KL-320-36. 36 volts 8.8 amps
    Gray
    Mar 2008
    3655
    That's not bad. You always have the option to go up to 48V if it runs slow for you. I assume your 640 is this one:
    http://kelinginc.net/KL34H280-45-8A.pdf
    CR.
    Speaking of running slow, when I'm jogging the motor seems to be running incredibly slow. Is there a setting in Mach3 I need to change? My jog rate is set at 100%...
    Hopefully I'll be ordering my motor mounts tomorrow from cnc fusion. If I find I'm moving slow I'll defininetly look into boosting the power supply...thanks for that tip btw...I probably would have assumed I needed bigger motors.
    What motor do I have? That's a good question. According to the page below I should have the motor you listed, however, the motor I've actually have is a KL34H295-43-8A. After you asked I looked on Kelling's website and can't seem to find it anywhere. So who know's what I've actually got?????
    http://www.kelinginc.net/Three34XCNCPackage.html
    Gray
  1. What turns 4th axis 'on' in MCX?
    By Donkey Hotey in forum Mastercam
    Last Post: 03-12-2008, 01:37 AM
  2. Beltdrive-stepper motor-stepper motor driver
    By Georg in forum Stepper Motors / Drives
    Last Post: 10-16-2007, 10:56 PM
  3. Stepper turns only one direction
    By jhowelb in forum Stepper Motors / Drives
    Last Post: 10-04-2007, 01:52 AM
  4. I'm done, but nothing turns
    By pbarsalou in forum DIY CNC Router Table Machines
    Last Post: 04-08-2007, 05:15 AM
  5. Okuma Vmc ,g80 Turns Spindle Off
    By qmas99 in forum G-Code Programing
    Last Post: 05-20-2006, 01:34 PM
