586,693 active members*
2,783 visitors online*
Results 1 to 13 of 13
    Feb 2007
    7
    formula for drill size
    I have a 1/2-13 tap ground special with a .4715/.465 pitch dia.,need help figuring drill size?
    Jun 2007
    3757
    10.8mm
    Or in medieval terms 27/64". for standard 1/2" UNC 13tpi.
    BUT oops..
    It may be smaller. What is with the regrind?
    Jul 2005
    12177
    Here is my bushman's method for calculating tap drill sizes.
    Find the decimal equivalent of 1/lead(pitch) in this case 1/13 = 0.0769"
    Subtract this from the OD; 0.5" - 0.0769" = 0.4231"
    Take the next fractional drill size up from this which is 7/16" = 0.4375" and you will get somewhere between a 65% and 75% thread; okay for most purposes.
    0.4715" - 0.0769" = 0.3946" so you could choose between 25/64" or 13/32".
    But all this is not necessary; the tap was ground down by about 1/32" so simply go down 1/32" from the standard tap drill size.
    Nov 2008
    8
    Pitch diameter on a standard 1/2-13 tap is .450, so your tap is oversize. Correct?
    Feb 2007
    7
    yes tap is oversize
    Jul 2005
    12177
    Quote Originally Posted by cam53 View Post
    yes tap is oversize
    Oops, misinterpreted by fast reading, I thought you meant 1/2" ground down.
    Anyway my bushmans method will work for 13tpi no matter what the diameter.
    Jun 2007
    3757
    Hmmm...
    Sounds like an allowance for galvanized bolts.:withstupi
    Jul 2005
    12177
    Quote Originally Posted by neilw20 View Post
    Some allowance, 0.015" to 0.02" on the diameter?
    Jun 2007
    3757
    Rattle proofed.
    At least it should be a nice fit in a 'clearance' hole.
    Nov 2005
    28
    1/2"-13 2B Pitch Diameter is pitch diameter of 0.450 to 0.4565, or an average of 0.45325 with a tap drill size of 0.4219
    So if your pitch diameter is .4715 to .465, or an average of 0.46825, wouldn't it make sense to have a tap drill size of +.015" larger @ 0.4369"?
    Feb 2007
    7
    yes ,thats what i thougth ,drilling it .015 to .020 larger . I have 1200 parts to tap wanted to be sure since i don't have go or no go gage.
    Feb 2007
    28
    Smile
    Hey Pop, For that many parts why dont you just take the time to make you a go and no go gauge.
    Nov 2008
    8
    Drilling oversize by the amout the tap is oversize is the solution. What material are you using? If it's soft like aluminum it's not as critical as if it's stainless steel or something even tougher. Also there's something called "First piece inspection". Self explanatory. With as many pieces as you are making you always allow for scrap.
  1. Tap & Drill Size
    By kiemkhach in forum Uncategorised MetalWorking Machines
    Last Post: 03-12-2008, 05:54 PM
  2. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
  3. what size steppers for a mill drill?
    By CNC Darren in forum Benchtop Machines
    Last Post: 10-04-2005, 05:36 PM
  4. Size motors for Mill Drill
    By Runner4404spd in forum Benchtop Machines
    Last Post: 06-19-2005, 07:09 AM
  5. What size of drill bit can be used for 1/2-10 acme tap?
    By starCNC in forum DIY CNC Router Table Machines
    Last Post: 04-29-2004, 11:36 PM
