586,832 active members*
3,149 visitors online*
    Feb 2007
    107
    thread milling help
    need example for milling an internal 1.375 x 28 tpi x .312 deep thread with a single point cutter.
    there is a center island (.75 diam) so I have to use a small thread tool to fit.
    thanks
    bad dog
    new fanuc oi controller on doosan mv-3016
    2932
    Let's try for a 1/4" dia. thread tool? If you need to make a thread at more than one location on the part, you should probably use nested subprograms. Store cutter radius in D01. Try this one ABOVE the part. Good luck.
    O1000 (MAIN PROGRAM)
    N1 G0 G17 G40 G80 G90
    T01 M06
    G00 G54 G90 X0 Y0 S6000 M03 (POSITION TO CENTER)
    G43 Z0.1 H01 M08
    M98 P1001 (CALL SUB)
    X5.0 Y0 (POSITION TO 2ND CENTER)
    G0 G91 G28 Z0 M05
    G90 M30
    O1001 (1-3/8 - 28 THREAD MILL SUB)
    G91 X0.51 (POSITION OFF THE ISLAND)
    G01 Z-.5 F20. (FEED TO 0.400 DEEP)
    G41 X0.1775 D01 F1.0 (APPLY CRC)
    M98 P121002 (CALL HELICAL SUB 12 TIMES)
    G01 G40 X-0.1775 F20. (CANCEL CRC)
    G90 Z0.1
    M99
    O1002 (HELICAL SUB)
    G03 I-0.6875 Z0.0357
    M99
  1. 3M and thread milling?
    By teamjnz in forum Fanuc
    Last Post: 11-04-2008, 02:09 AM
  2. Thread Milling on v22
    By PinMan in forum BobCad-Cam
    Last Post: 07-28-2008, 12:42 PM
  3. Thread milling
    By TT350 in forum Tormach Personal CNC Mill
    Last Post: 12-01-2007, 04:01 AM
  4. Thread milling
    By wjfiles in forum MetalWork Discussion
    Last Post: 01-08-2007, 11:13 PM
  5. thread milling
    By STS_Kevin in forum Daewoo/Doosan
    Last Post: 11-29-2006, 01:50 AM
