Been trying to get this part made for awhile, but when I do the 'verify' for any of the posts, I just get a flash of the cutter and no actual end result. RhinoCAM and MadCAM import it fine. ANy ideas?
I assume that you mean 'verify' in Mastercam. I think you have your stock set wrong. I opened both MC9 files in MCX and they ran but didn't do anything but bonk briefly into the stock you had set.
When I reset the stock to actually contain the geometry, it verifies just fine. The output (G-code) should be the same whether or not you have the stock set correctly but you won't get a clear simulation.
Greg
Thanx, turned out to be a different problem altogether, but it's working now. But I am considering switching over to RhinCAM.
