587,591 active members*
3,911 visitors online*
IndustryArena Forum > CAM Software > Mastercam > importing Mastercam art files in Rhino
Results 1 to 5 of 5
    Nov 2005
    938
    Is there a way to save a mastercam art (MCA v9) file and then import it into Rhino for further editing and eventual export to visual mill.
    I have a number of MC Art projects that I would like to incorporate into larger Rhino projects and then export them to VM5 as one piece.
    (I posted this question to the McNeel usenet forum with no responce yet, s I'll give it a shot here too)
    If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
    Steven
    Mar 2006
    1013
    Once you open the Art file in Mastercam, you should be able to export it as any type of file you like. Did you try it?
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
    Mar 2006
    1013
    Actually its File - Convert - ......
    Iges, DXF
    Mike Mattera
    Nov 2005
    938
    Mike,
    Thanks, I'll have to try that.
    Steven
    Apr 2003
    3578
    sdantonio you will not beable to output the art file as an Iges or DXF.
    I can't remeber in V9 of art if we had the option to out put to MC a surface file like we have these days then you could do Iges with lots of little surfaces.
    if you can work with STL then you save that and use in Rhino.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
  1. Importing from Rhino to Mach
    By gregrnel in forum Mach Mill
    Last Post: 03-05-2009, 06:41 AM
  2. About Importing Files
    By Gorillakilla in forum Mach Software (ArtSoft software)
    Last Post: 04-11-2006, 10:37 PM
  3. Importing files to turbocnc
    By mikburts in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-18-2005, 12:35 AM
  4. importing files to machine
    By fastolds in forum GibbsCAM
    Last Post: 06-23-2005, 01:48 PM
