586,980 active members*
4,026 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Send/receive program without output/input push
Results 1 to 13 of 13
    Mar 2006
    107
    Is it possible on Fanuc 0M to send program to control without push on input and send (take) program from control to PC without typing on machine "O####, Output start"...?
    Sorry for bad english
    Jan 2007
    333
    I've never seen or heard of a way. There is a way to be at the machine and send or receive prog's without ever having to be at the PC.
    RS232 DNC communications
    At Dolphin we have ported our Communications software to run on
    handheld PDA's which support Windows platform. The PDA is connected
    to the PC via a Synchronised docking station, CNC upload/download is
    required the PDA is taken to the CNC and connected via a USB/RS232
    converter. Details available on www.dolphin.gb.com .
    Dolphin CAD CAM Ltd
    Mar 2006
    107
    Quote Originally Posted by bborb View Post
    Can someone explain this?
    Obviously you should have software with this feature?
    Which for example?
    BTW, sorry for bumping really old thread.
    2932
    Predator DNC uses a Remote Request to initiate program transfer from the NC. The operator never has to go near the PC. Also, when the operator wants to save the program from the CNC, he/she just PUNCHes the program.
    Mar 2006
    107
    Quote Originally Posted by dcoupar View Post
    PUNCHING
    Is it possible that every program that is punched will be saved in it's own file and under same name as program number is?
    READ (INPUT)
    Is there any explanation how remote request works, and what features there are?
    Is it possible that I push INPUT button just one and I send few programs (in single file or multiple files?) at a time, with one INPUT? This is not related to remote request. This is for Fanuc 0M
    2932
    Quote Originally Posted by padobranac View Post
    PUNCHING
    Predator has a Remote Autoname that will automatically name the program (usually with the O number) when saving the program to the PC.
    READ (INPUT)
    You have a Remote Request program as follows:
    O8001 (PREDATOR REMOTE)
    (LOAD O1234)
    M30
    The operator PUNCHes that program, then prepares the control to READ.
    After a preset delay Predator sends the requested program (in this case O1234) to the CNC.
    The Remote Request program can contain multiple LOAD commands:
    (LOAD O1234)
    (LOAD O1235)
    (LOAD O1236)
    M30
    Predator will send all three programs.
    Mar 2006
    107
    (LOAD O1234)
    (LOAD O1235)
    (LOAD O1236)
    M30
    So do I need to push INPUT button for every of these programs, or it can be done with only one INPUT push?
    That is only question that remained unanswered.
    Thank you very much for help.
    2932
    Predator will send all the programs with one "INPUT" push. Your Fanuc control has to have parameters set to continue reading after M02, M30, or M99.
    Mar 2006
    107
    Yes, I found these parameters.
    If I have all program without % at begining and at end of programs, first program that is sent is lost, not recognized.
    If I have all programs with % at begining of it, transfer is terminated at begining of 2nd program (because of %).
    SO, solution is that first program does have % at begining, others not.
    Also if I put % at the end of last program that is sent, transfer will be terminated automaticaly. Otherwise I have to hit Reset button to stop transfer.
    Since now I had all my programs and subprograms in this shape, in single files:
    :1234
    M30 or M99
    Is there any solution for this?
    2932
    Predator can strip the % from the programs when it sends them. It also can add a % at the beginning and end of the "conversation". So even if your programs look like your example, when Predator sends them, it looks like this:
    :1234(MAIN PROGRAM)
    M30
    :1235(SUB 1)
    M99
    :1236(SUB 2)
    M99
    Mar 2006
    107
    Perfect!
    So Predator does have all features that I have been dreaming about.
    I asked for access code for timed evaluation of Predator (with NIC number) but no answer for a very long time. Why?
    Oct 2010
    Hey guys!! New to the site. Was wondering if anybody knew where to get a free copy of the fanuc ez guide software for a lathe to run on a laptop. I´ve recently moved country and just started a job and this software would be a great help to me for programming becuse all the machines here are in spanish and my spanish is not that good yet. Cmobilaah
  1. How do I send/receive NC Programs on Mitsubishi FX EDM
    By barnescomputer in forum Waterjet General Topics
    Last Post: 03-25-2022, 02:32 PM
  2. program input/output with RS232 port on Mitsubishi 50L
    By Chuck Reamer in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-21-2013, 08:56 AM
  3. Remote send/receive
    By 2hoop4inch in forum Haas Mills
    Last Post: 05-28-2009, 12:21 AM
  4. WIRELESS send & receive
    By SpeedMetal in forum Milltronics
    Last Post: 01-21-2008, 11:04 PM
  5. looking for send program to cnc;
    By raymon in forum DNC Problems and Solutions
    Last Post: 08-22-2006, 04:35 PM
