587,047 active members*
3,164 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Put tool information into program
Results 1 to 7 of 7
    Aug 2004
    73
    How can I modify the post that the tool information show up into the Gcode program beside using the Comments.
    Thank you
    Mar 2008
    28
    Put them in threw your editor if you need to add more comments. Otherwise customize your post.
    Apr 2003
    637
    deleted
    May 2007
    71
    It depend on what kind of Post you are using and What kind of Tool Information you want to output. If you used SPost, it is easy!
    You just need to edit your Surfcam.pst and add the -toolinfo in the Command line
    Like these:
    PostItem DMC-64V 635V TNC530 ISO
    Status DMC-64V TNC530 ISO
    Command "C:\SURFCAM\Velocity3\INC2APT" -op -toolinfo -I "%p%n" -O "%p%N.apt"
    ChDir "C:\SURFCAM\Velocity3\SPOST"
    Delete "%p%N.I"
    Command "C:\SURFCAM\Velocity3\SPOST\SPOSTM" "%p%N.apt" 3187 "%p%N.I"
    Task "C:\SURFCAM\Velocity3\Editnc\editnc" "%p%N.I"
    May 2007
    71
    If you are using MPost then do followings:
    Edit your post that you are using: (Postform.m or xxxx.m3)
    1. Tool Change and First Tool Change:
    add
    T[Tool] M6 (0 d[ToolDiam] s[Style] c[corner] )0
    2. At that post before end of that post
    add
    Replace "d" with "D"
    Replace "c" with "CR="
    Replace " )" with ")"
    Replace "s000" with "BALL"
    Replace "s803" with "BALL"
    Replace "s001" with "ENDMILL"
    Replace "s801" with "ENDMILL"
    Replace "s002" with "BULLNOSE"
    Replace "s802" with "BULLNOSE"
    Replace "s003" with "TEARDROP"
    Replace "s004" with "KEYWAY"
    Replace "s005" with "SHELLMILL"
    Replace "s006" with "TAPERED BULLNOSE"
    Replace "s007" with "TAPERED ENDMILL"
    Replace "s008" with "DOVETAIL"
    Replace "s009" with "CHAMFER"
    Replace "s010" with "CORNER ROUND"
    Replace "s100" with "CENTER"
    Replace "s101" with "DRILL"
    Replace "s102" with "TAP"
    Replace "s103" with "REAM"
    Replace "s104" with "BORING"
    Replace "s105" with "CUSTOM1"
    Replace "s106" with "CUSTOM2"
    Replace "s107" with "CUSTOM3"
    Replace "s108" with "CENTER"
    Replace "s109" with "2EDGE"
    Replace "s110" with "COUNTERBORE"
    Please try by yourself!
    Mar 2008
    28
    Quote Originally Posted by sinderal View Post
    add
    add
    thanks for the info
    Aug 2004
    73
    Thank you
  1. can we use the tool eye on program
    By Bala in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-20-2008, 07:25 AM
  2. how to program the tool cut like in video?
    By qmas99 in forum Surfcam
    Last Post: 07-17-2007, 06:54 AM
  3. 6MB Tool # registration program
    By steedspeed in forum CNC Machining Centers
    Last Post: 12-24-2006, 07:20 PM
  4. Set Tool Offsets in NC Program??
    By alfalfa in forum CamSoft Products
    Last Post: 10-06-2005, 05:47 PM
  5. Does V20 program tool tip or tool center
    By Pat in forum BobCad-Cam
    Last Post: 06-17-2005, 11:46 PM
