586,655 active members*
3,111 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Broaching screwdriver slots on lathe
    Apr 2004
    353
    Has anyone ever seen a tool that can broach a slot on the face of a piece for a flathead screwdriver?
    We need to make a bunch of brass shear-pins with a slot on the face, I was thinking of using something like a hacksaw blade in the turret and moving the X axis across the face of the part with the spindle locked. Then just part them off.
    Jul 2005
    12177
    Quote Originally Posted by laka View Post
    .....We need to make a bunch of brass shear-pins with a slot on the face, I was thinking of using something like a hacksaw blade in the turret and moving the X axis across the face of the part with the spindle locked. Then just part them off.
    Don't use a hacksaw blade, just use a single point tool and take several cuts each a few thou deep. You should be able to do it at a very fast feed rate, maybe even a rapid, because your feed rate in this instance is actually your cutting speed.
    Apr 2004
    353
    Crap.. I just checked and our lathe doesn't have a spindle lock, only spindle positioning. Do you think doing multiple passes would work still, or would she move around?
    Jul 2005
    12177
    Cross fingers and try; spindle orientation (positioning) can hold the position quite good provided not much turning force is exerted. If your cutter is exactly on center iot should not have much tendency to turn the spindle.
    Dec 2007
    617
    Hi:
    If the tool is dead nuts on center there will be no force to cause rotation. (in theory)
    regards
    Can't Fix Stupid
    May 2008
    84
    If you have a backgear, leave the bullgear engage (pin in the side of the gear) while the backgear is engaged. It will be locked solid.
    Don't forget to undo it before you hit the power switch
  1. Rotary Broaching
    By rhino in forum MetalWork Discussion
    Last Post: 09-16-2011, 07:15 PM
  2. Broaching on CNC Mill?
    By tkoden in forum Uncategorised MetalWorking Machines
    Last Post: 09-16-2011, 07:08 PM
  3. Which press for broaching?
    By Arnaudb in forum MetalWork Discussion
    Last Post: 03-30-2008, 02:19 AM
  4. Keyway broaching on Lathe (need Y axis?)
    By pmurdock in forum MetalWork Discussion
    Last Post: 12-29-2007, 04:20 PM
  5. Broaching advice
    By Al_The_Man in forum MetalWork Discussion
    Last Post: 12-19-2006, 12:03 PM
